They display the key as soon as you purchase the upgrade and email you a copy shortly afterwards. If you install (not acquire a key) MC before the end of the month it's free. You can use this URL to get a key...
The link works now... unless one app (or more) has been updated it won't install in Windows 8. Looks like DTB Addin is the guy that won't install. I'm trying to run down a newer (Beta) version and if I have any luck I'll post here.
http://www.engadget.com/2009/10/22/how-to-automatically-skip-commercials-in-windows-7-media-center
UPDATE: I got hold of the early release of DTB Add-in and then ShowAnalyzer wouldn't install (in Windows 8). Back to square one I guess... if I end up using my HTPC in the den I'll keep digging for a commercial skip app. Since I commercial delay viewing most of the time I need something that works on the fly... and doesn't convert the file into another format.
Personally, I'd clone the disc (to a larger one) and wipe it during installation. Nothing like starting from scratch... and you can always punt by returning to the original disc at anytime. Within a couple of hours I was back up and running with MC and XBMC (as before).
Win8 well named, it took me 8 hours to download on slow DSL today. But you can use computer while it downloads. WMC was painless, same look and feel. After reading so many reviews about how 'hard' it was to get accustomed to WIN8, I was surprised that it loaded my old desktop without having to find the retro add-on reviewers talked about. I can pretend it's still WIN7 whenever I want, but I think I'll like WIN8 features. HP had all kinds of dire warnings and none of it came true, MS did a good job of anticipating updates, and I only had a couple things that needed downloading from HP, which wasn't as friendly. The free WMC code indicated it might be 72 hours, but the code was in my email when I looked an hour later. I had to upgrade my BD reader for WIN8, but that was not hard, just annoying -- loaded with ads.
I recommend cloning the disk. That way you can be 100% sure you aren't going to mess anything up... I got smart the other day (using Partition Wizard - I have had great luck using it in the past to do the identical thing) and tried to migrate all of the recordings to a separate partition I used it to create. I would copy recordings over to the new partition and then increase its size with the space freed up from the original. Keep repeating until all of the recordings are transferred...
I have done such in the past without issue however this time for some unknown reason during the last transfer or partition resizing the new partition went south. Even a recovery utility couldn't find any data on the partition and I had a heck of a time even deleting it to start over... long story short clone and drive and do what you may with the new one.
My issues were it would skip over parts of a program. Especially, the beginning and the ending of shows. I have MC set to record two minutes early and it would get confused when the previous show ended and the scheduled one began. It would also at times lose the last segment such as on The Big Bang Theory. Which was worse as the recording would end (if I didn't catch it right away) and I'd have to replay it and skip to the last couple of minutes. All and all I miss it and when it works (most of the time) it's rather cool.
One plus I'll give Windows 8 is it handles swapping AV receivers rather nicely. With Windows 7 it seemed like I had to go in and reconfigure the sound card especially for HD audio. With Windows 8 it just works... whichever one I boot up with appears and it's ready to rock and roll. I guess it could be the newer Intel HD drivers although whatever the reason it's a lot nicer.
All that while I was trying to learn how to use Windows all over again because it looks like they replaced the Start menu with the Program Manager from Win 3
WTF is the matter with M$ anyway?
If, after awhile, you find it intolerable, this is what myself and many, many others are using, so we have a start button and menu back, and we don't have to deal with the Metro interface ever again, because it boots up right to desktop:
www.iobit.com/iobitstartmenu8.php, or
(Win 7 came with the correct driver.)
It's what they do.
It hasn't happened to me yet, but I have other problems with sleep/wake: BSoD in Win 7 (haven't tried it in Win 8 yet) so I've been keeping the PC on (unless I know there are no recordings scheduled and shut it down completely).
For anyone looking to re-purpose an older (non HDMI) PC Fry's has the Diamond AMD 6450 for $20 (after rebate) this week. It does HDMI HD audio as well as 3D so its got you covered if you go down that road later on.
I still find it confusing... the video card being your sound card (pass through per se). I found out the card doesn't support Contrast Enhancement (Dynamic Contrast) of which the i3 has a bug doing. It's fanless and I wanted to use it to get around the bug... oh well.
) So Friday I made a system image of my little Win 8 drive on my big Win 7 drive, created a Win 8 rescue disk, and removed the Win 8 drive from my system. Now I'm back on Win 7, but I have Win 8 ready to go once all the software (commercial skip, WMC add-ons, etc.) has caught up with it and that killer Win-8-only app comes out. It was a lot of work, but not a bad deal for under $50 ($15+tax for the Win 8 upgrade, plus $30 or so for the drive that holds it.
I'm hoping XBMC becomes mainstream enough to be an easy replacement for WMC. Version 12.0 was just released and I tried again... as before running into backend server issues. I got a little further than the last time and I think I'll give it another try once I read about other Windows 8 users experience. I use my Desktop instead of the DVR PC for playing around so I can play all I want...
One item of note although it could be my imagination is since I upgraded to Windows 8 my Xbox extender feels a little snappier. Especially Skip Forward and Back... there wasn't much lag before however now it's extremely close to the PC's speed.
