AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › dayton sub-120 upgrade to psw505?
post #1 of 4
been pretty happy with the dayton sub 120 i have had for about 4 years and wondering if an upgrade to a polk psw505 would be a significant upgrade? can get the polk for under $300. any other sub that would give me more bang for the buck under that price point? F12 comparable lesser greater then the psw505? F12 an upgrade from the dayton?
post #2 of 4
Neither of those would be much of an upgrade. Here's a sub that will get you deeper, for a hair over budget
http://www.newegg.com/Product/Product.aspx?Item=N82E16882780078&Tpk=rw12d
post #3 of 4
I agree with Jay 1 as those subs mentioned would not be much of an upgrade at all as it would be more of a lateral move, The Klipsch rw12d Jay 1 has posted can be had from time to time from New Egg for $300, it seems they are on sale about every other month.
You mentioned you were pretty happy/satisfied with the Dayton 120, I assume you are looking into more "umph"... or are you looking just to fill the room more?? If youre looking to fill the room more then I would suggest running dual subs. Running dual wount really give more bass in essence but it fills the room out much more. I see you can get the Dayton sub ( now 1200) for $120... looks as its a very good price, I have never had the chance to hear the Dayton but I did at one time have dual Bic Pl-200, which is a slightly better performer than the F-12 you mentioned. THe Bics are a pretty decent sub esp. when you take in the price its just that I dont think it may be a HUGE difference from what you have already.
When I replaced my dual Pl's with the PA-150 I noticed quite the difference, as the PA-150 hits harder than the Bics every could. I now have an Outlaw EX along with the PA-150 as I can tell a difference between the two but onlly in the lower hz such as 18-30. Of corse both subs are over the Budget you listed as the PA-150 I think can still be had for around $380 as the OutlawEX is $650.
I guess my point is unless your willing to strech the budget you listed I dont think there will be much more of an inprovement IMHO. If you are just looking into filling out the room then I would just suggest going with another Dayton 1200 for $120 as that will save you money as well.
post #4 of 4
thanks for the input gentleman. the dayton got whacked by lightning along with most of my other av equipment. when i looked up getting another i saw the power of the amp in the 1200 is less and just thought i maybe could find something a little better. I have seen reference to the klipsch and would love to find one on sale. not an immediate need as at the moment i am getting by on the speakers in my half fried panny plasma while i wait for the insurance check to show up. thinking it might be worth a wait for a bit to see if that klipsch goes on sale is what i'm thinking from your input
