Originally Posted by
ClearToLand
SUBTITLE: ABC HD Quality / Vista vs W7 WMC File Types... {lightbulb}
- As I posted, when ABC finished, CBS settled in @ 15Mbps. So, if NBC is the same quality, 30Mbps sounds right. {thumbsup}
You can get bitrate information of A/V files using MediaInfo. I also see bitrates directly in my TiVo transfer programs which is why I tend to notice them more often. CBS-HD was historically pristine 1080 HD with no sub-channels and outputting close to 19Mbps. Recently in the Philly market they have implemented a worthless SD sub-channel and reduced their bitrate to ~15Mbps. NBC-HD had a sub-channel to start and has historically output 1080 at ~15Mbps. FOX generally runs 14-15Mbps outputting 720p. Recording any pair-wise combination of those three from the HD Homerun across the PLA's is a worst-case scenario for me -- I've done a lot of it over the summer and my configuration "passes".
Nothing you have written here is inconsistent with what I stated, you just complicated things by introducing Vista-MC and the notion of post-processing a video capture.
I was only talking about .wtv files from Win-7 WMC -- I don't have any Vista PC's. So my statement stands that I don't know of any media players that directly play a .wtv file.
As far as post-processing to convert a fully recorded .wtv file to .dvr-ms or something else, that misses the point I was making about the .ts file -- you can stream a live .ts file with your media player while it is still recording on your media-PC. That makes all the media players in your house into "DVR-extenders". Since the media players I am familiar with don't play .wtv files, you can't do that when recording with Win-7 WMC -- you have to use an Xbox as an extender. If you are interested in post-processing I suggest Video ReDo. VRD reads unprotected WMC files and you can edit/recode/save them to any of the popular open formats. I do a lot of commercial-editing with VRD of both .tivo and .ts files because I collect series I don't have time to watch during the season. VRD is a great tool for this -- I prefer to save the edited recordings as .m2ts files, myself.
I can't remember if you are OTA or cable. What I've written about recording and live-streaming .ts files only applies to the HD Homerun recording OTA or clear-QAM cable. If you have the HD Homerun Prime cable-card model, you have to use WMC because of the cable DRM requirements. NextPVR only supports OTA and clear-QAM on the HD Homerun, not the HD Homerun Prime.
I was not aware the PBO had TiVo-like skip forward & backwards. I will have to look into that, one of those could prove very useful. Thanks for the tip.
Edit: Silly me, you keep citing the HDHR3-US in your post which is the 2-tuner OTA/clear-QAM model that I have. So, yes, NextPVR will work fine with it to record your OTA/cable source as .ts files. The 7-day guide service costs $25/yr but you can get a 2 mo trial subscription for $6. PSIP is worthless as a guide but perfectly useful for experimental recordings.
Edited by Kelson - 8/8/12 at 8:03am
