Hi,
I have some information on my PC.
it can be served as a flash video or as a some web content (html)
or even as a simple image(jpg or png)
This information is dynamic (Changing in every 2 mins.)
I do have a TV with an antenna in some other room.
i need to display the content on my pc on the TV, over the TV channel being watched (OSD) . the info will transfer to the TV unit using LAN(ip)
The OSD info should stay remained (refreshing in every 2 mins) even though the TV channel is changed
(i cant use a STB since the local TV channels are analog)
I'm very tired of searching a solution for this. Any idea is appreciated.
Sorry for my bad English. Thank You.
