Hi!
I'm a newbie to good home theater systems though I've been reading a few months now!
I am based in India where every component is about twice as expensive as elsewhere...so please help me sort out this confusion! Thanks!
I am planning to purchase the Marantz NR1402
I am planning to buy a 5.0 BS/5.1 sub-sat system to go with this for a 150 sqft room-budget around 800-900$
From all my reading and out of availability - I have found the following:
Bookshelf system:
1) Pioneer SP-PK21BS (5.1) which I can get here for about 700$
2) Infinity Primus P153x4 + PC251 center channel for about 900-1000$(estimated)
3) Pioneer SP-PK41BS+SP-PK21BS (5.1) which I can get here for about 900$
Sub-Sat
1) Polk Audio TL350 if I can manage to ask someone to get them from USA- around 700$
2) Def Tech ProCinema 800 5.0 at about 700$- from USA
3)Energy Take Classic 5.1 at about 700$- from India
paired with a ~350$ Paradigm Cinema Sub/350$ Wharfedale SW150 sub
I wanted to know if these higher-end, high rated sub-sats can compare with the lower end bookshelves...for 50% music and 50% movies in a small room!
Considering my relatively constrained options and budget, please help me out deciding!
Any 600-700$ 5.0 sat system from USA would do, or a 300-400$ 5.0 BS system I can get here for the same price?
Bookshelf system:
Sub-Sat
