AVS › AVS Forum › Display Devices › Display Calibration › i1Pro and third party calibration software
post #1 of 5
Hey all,
I'm new to this calibration stuff but basically I just want to calibrate my monitor and possibly create a printer profile and TV. I bought an i1Pro spectrophotometer 2nd hand but there was no software with it. What is the best software for a reasonable price that would accomplish this. I got such a great deal on the i1Pro which is probably overkill for my application but I though I'd give it a try. Got any ideas on what software I should buy?
Joe
post #2 of 5
If you do not want to do TVs which you will .. but if you don't then Spectracal has CalPC http://store.spectracal.com/consumer/calpc-monitor-calibration.html
post #3 of 5
The old HCFR 2.1 works with the i1Pro spectro and it's free.
http://www.homecinema-fr.com/colorimetre/release/Setup_v2_1_0.exe
Jason
post #4 of 5
Thanks, I'm going to try the HCFR Colorimeter software.
post #5 of 5
HCFR is a great way to start out, then move on to one of the better 'paid' offerings when you have a good grasp on what's going on.
Jason
