AVS › AVS Forum › Classifieds › Audio Gear › Paradigm Reference Signature Servo 15" Subwoofer
For Sale: Paradigm Reference Signature Servo 15" Subwoofer
post #1 of 10
This Classified is Closed
For Sale:
Will Ship To: Nowhere -- local only
If you have expensive taste but wait for the deals, consider this audiophile 15” subwoofer from Paradigm. Its accurate to 10Hz (but many can’t hear below 16Hz). In a typical room, it can push 123 DB with its 1200 watt RMS (4,500 watt peak) class D amplifier.
The paradigm Signature Servo is a reference grade product and when positioned well in a regular room, it will be enough bass. The trick to getting great bass from this is finding the sweet spot in the room. Its a bitch, but well worth the time. It took me a week but finally discovered a how-to that said not to put it in a corner. When placed near the side wall between the front and rear speakers it woke the room up for the 2 channel and home theater configurations. The bass goes deep, low and its quick. It will vibrate your pant legs and will piss off your room mates (but when nobody is home its party time).
It weights in at 100(ish) pounds and has a very nice finish.
I did months of research in ’08 to find a sub and this was the sub to beat, all other reviewed subs had to measure up against this beast of a sub. I found one used at a high end audio shop (Definitive) and bought it. When they put it in my truck (in the extended cab), they tweaked the volume knob. So the knob is bent but works fine. Its also missing the grill.
It does not have the digital room correction, you will need to do things the old skool way (which works fine!).
It has XLR and RCA low level single channel inputs (can use one at a time), auto on/off, trigger on/off, variable cut-off 35-150Hz, phase alighment and bass contour adjustments.
Link to bigger pictures and sales brochure (a good read).
Local purchase only. Zip code 98052 (Redmond/bear creek)
Cash only
Edited by Joelz - 8/31/12 at 10:43am
View All More from This Seller
post #2 of 10
ttt
post #3 of 10
Hello,
I saw your add on craigslist for this subwoofer and sent you an email on it yesterday, but it seems the post was deleted or expired before I could get my message out. I am interested in your subwoofer it is still available and have a few questions as well. If you are still selling it please contact me, PM sent.
Ryan
Edited by lsmjd - 8/12/12 at 2:00am
post #4 of 10
Yes, its availble. PM replied to. Thanks!
post #5 of 10
I can't send any more PM's because of the 2 message's per day limit. I can pick it up since you cant deliver, just let me know when your available.
post #6 of 10
Edited by Joelz - 9/2/12 at 10:12am
post #7 of 10
post #8 of 10
Hello, Is this sub still available? Thanks. My email: cayward@msn.com
post #9 of 10
post #10 of 10
I'd be interested if you considered shipping..send me a PM
  Back to Forum: Audio Gear
