AVS › AVS Forum › Audio › Speakers › Needed: 5.1 spkr package, matching Onkyo SR706
post #1 of 5
Have about 1500.00 or so to look at a 5.1 speaker package:
Room : 18 x 26 x 9
Am looking at HSU Hybrid 2 5.1 package so far..
any thoughts?
thank you
post #2 of 5
Those satellites seem to be a bit small for use in a 4200 cubic foot space. You might want to consider towers for the fronts instead.
If you opt to go that route a few potential package options are:
If you want to go separates then matching the Premier Acoustic PA-6F, PA-6C and PA-6B would be a nice system. You could also try using the EMP Tek E5Ti, E5Ci and E5Bi.
That leaves about $700 for a sub, which could buy you something like the Epik Legend, HSU VTF-2 Mk4 or Outlaw Audio LFM-1 EX.
post #3 of 5
+1 on Jims post
post #4 of 5
2 polk monitor 70's and a Polk cs2/20. Then two hb-1's for surround and a vtf 15h for sub or two vtf 2.4's.
butter and jelly please.
post #5 of 5
With the sub, I think the HSU package will be fine. How far away do you sit from the speakers?
  Back to Forum: Speakers
