Originally Posted by eghill1125
I gave it another shot and something just isn't working. To rehash.. I have the C3 meter and Calman 5 with my LG lw5600 LCD.
When I set the 2 point grayscale with 30-80%, I have no red in the 80% and only a small bit in the 30%. Blues are in the 112-15 range. My initial color temp readings are in the 8900-9000 range. Everything out there says the colors are really good on this tv and I believe they are. Just not sure why I have such a bad reading for temp and reds. They are basically missing through the whole 2 and 10 point grayscales. Turning contrast down has not helped at all. I have tried contrast from 94-72. The color clipping pattern with a contrast of 90 shows red stopping at 245 and green and blue at 247-249.. As everyon would figure, adding red in all the % points does nothing but kill the picture and I am left with nothing but pinks instead of whites..
Any ideas for me. I can get into the SM without a problem, but figured the controls are there without it, so I wouldn't yet.
The meter is brand new so I wouldn't think it is the problem..
perhaps you're starting in the wrong mode.
Try using one of the warmer presets for color temp.
(which doesn't help), we can follow this:
and to my support load)
