AVS › AVS Forum › Display Devices › Display Calibration › CalMan 5 Release Notes and Discussion
CalMan 5 Release Notes and Discussion - Page 64
post #1891 of 2247
Tried LS - definitely NOT user friendly unless you've been out and about the calibrating field for awhile! Another words, Pros, or near pros.
For the amateur, to semi-professional, to the full professional Calman will do the job for probably 90% of the Calibrations that need to be done.
I've input ideas, seen some implemented, quite a few hair brained ideas rejected, but my LG 55LHX has continued to improve with newer Calmans, some of my out of the box ideas, and still after 3 years, I still prefer to watch, and improve!
Even my last weird idea for calibrating these sets caught my wife's eye, and I got a `You're finally getting it dear!' Never seen these sets look this good!
Had to love (not) Calman 3, and trying to get those dang points to align properly! Then 4, and a sigh of relief, and now the continuing to improve 5.
You can almost feel the itchy calibrators just waiting to try that next new Beta, and the postings of when the next will be out. Haven't seen that with either LS or CM!
Issues with Build # 1386 - Continuing Loop for Saturation Uniformity - Pre and Post Calibration
Edited by p5browne - 11/29/13 at 8:41am
post #1892 of 2247
Lumagen Radiance XE/XE+/XE3D/XE/XE+/XE3D/Mini-3D/XD/XD3D + Radiance 20XX Series (2021, 2022, 2041, 2042) New 112513 Firmware Update
Release Notes
Fixes audio issues seen that could give noise or no audio with some equipment.
Added a shorter option for audio mute length under Input: Audio Setup: Mute Control. The default is mute length is "Long" but options include Short, Medium, and Long. Previously, the options were only Short and Long which have now become the Medium and Long values.
Several small menu improvements and fixes.
Small improvement in input switching speed.
Download Link
post #1893 of 2247
post #1894 of 2247
Lumagen Radiance XE/XE+/XE3D/XE/XE+/XE3D/Mini-3D/XD/XD3D + Radiance 20XX Series (2021, 2022, 2041, 2042) New 120213 Firmware Update
Release Notes
Fixed up an older bug (recently made worse in 112513) which depending on equipment and settings could intermittently (or regularly) result in delaying turn-on of video output. Could be double normal output turn-on time and feasibly even longer.
Bugfix for issue created in 112513 release causing an output to not turn on if only one output is connected.
Download Link
Edited by ConnecTEDDD - 12/6/13 at 5:01pm
post #1895 of 2247
Never noticed it. I guess because one output goes to the Halite, and the other the my Yamaha AVR. Will install the new download anyways.
Note: Download is now # 120213 New Download is 120313
http://www.lumagen.com/testindex.php?module=updates
Note: Shut your AVR Off before starting the FW Upgrade, elsewise the update may not complete.
Edited by p5browne - 12/9/13 at 4:29pm
post #1896 of 2247
Lumagen Radiance XE/XE+/XE3D/XE/XE+/XE3D/Mini-3D/XD/XD3D New 120313 Firmware Update
Release Notes
Fix for some older HDMI/DVI displays (particular case was a DPI Titan 250) not showing video with last two firmware revisions (112513-120213).
Download Link
post #1897 of 2247
Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 120313 Firmware Update
Release Notes
Small fix for some older HDMI/DVI displays not showing video. (If you see video then you can skip this update) (Update time ~3 minutes @57k)
Download Link
post #1898 of 2247
Something I've been wanting to ask about Calman 5.
In Chromapure, when using an i1pro2, you don't have various "display type" options to select.
In Calman, you do. There's an option for plasma.
Does the option feature actually do anything with an i1pro2 or is it just there due to needing it available for color meters that rely on tables?
post #1899 of 2247
No, it doesn't matter what display type you will select, exept if you need to take Illuminance readings (labeled as Facing Projector options) where you will have to attach your i1PRO diffuser for that.
post #1900 of 2247
ConnecTEDDD - you're stammering! All your various posts are double posting! Don't know which Web Browser you're using, but you're going to have to switch to Apple Safari, or Google Chrome. Mozilla FireFox - stay away from - too many security issues.
post #1901 of 2247
Hello, they are not the same posts, Lumagen has released the firmware update for Radiance Series only, but after 10-12 hours they released the same firmware for Lumagen Radiance 20xx Series users. This is the reason you see double posts, first post was to inform the Lumagen Radience users, second post for Radiance 20xx users. Lumagen has slight difference release notes as you can see, but mainly it fixes the same issues.
post #1902 of 2247
But i just saw and delete the double post you mentioned, it was about an i1PRO Question reply.
post #1903 of 2247
I apologise - after affects of watching 3D TV!
post #1904 of 2247
No problem, I can understand, Active Shutter Glasses after effects loooooooooool
post #1905 of 2247
New Calman Beta coming out, but due to some timing bug issues, it has been delayed.
post #1906 of 2247
CalMAN 5.2.1 is ready now but we are under NDA with one of the features added. As soon as the NDA has been lifted we will make 5.2.1 public.
post #1907 of 2247
To early yet to open our Christmas Present!
post #1908 of 2247
Hello: Am I able to use my OEM i1 Display with the Calman RGB feature included in my Enthusiast license to calibrate PC/Mac monitors?
post #1909 of 2247
Hello, yes you can.
CalMAN Enthusiast is also the only home video software from SpectraCal that includes CalMAN RGB - the latest in monitor calibration software for Mac and PC computers.
SpectraCAL's CalMAN Comparison Chart says that you get 2 client licencies.
post #1910 of 2247
Hello, yes you can.
Thank you!
post #1911 of 2247
Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 120413 Firmware Update
Release Notes
Fix for an error in 112513-120313 updates which doesn't always get the input colorspace set up completely correct causing greens to be a little off and reporting incorrectly on the Info screen. (Update time ~3 minutes @57k)
Download Link
post #1912 of 2247
The Calman 5.2.1 is now going to be a Christmas Present, Boxing Day Special or a New Years Grand Start?
post #1913 of 2247
We are looking at CalMAN 5.2.2 on Friday
post #1914 of 2247
What will be in 5.2.1 and 5.2.2 besides a special surprise that was the reason for the NDA?
post #1915 of 2247
What or who is the NDA?
post #1916 of 2247
Thought I read here they were waiting to release the new version until some non disclosure clause was lifted...?
post #1917 of 2247
I believe we are licensing out the support for the offending hardware.
Hopefully we will have a release out in the near future, not today.
post #1918 of 2247
So here is the plan. We did not want to hold up the release any longer for the NDA. So we are going to split the release into two.
CalMAN 5.2.2 later this week, is mostly bug fixes and some minor updates. CalMAN 5.2.2 will be the last release to support Windows XP.
CalMAN 5.3 will be mid Jan includes significant updates.
post #1919 of 2247
does any of the 2 releases include the Eizo calibration ?
post #1920 of 2247
We are still under NDA but CalMAN 5.3 will have significant hardware updates.
