AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Complete newbie need help picking amp/receiver
post #1 of 2
I'm sure you guys get this a million times, so I'm sorry if it's a hassle. I've tried doing research into how to pick an amp, but I just can't seem to figure it out. I read that you were supposed to find an amp that supported double the wattage of your speakers, but I don't seem to be able to!
I ordered these speakers: Amazon.com: Sony SSF-5000 Floor Standing 3-way Speaker (Pair)
Am I right in thinking I need a 300 watt amp, since the speakers seem to take 150 watts? I found the Onkyo M-282 2-Channel Power Amplifier, but it's $100 more than the speaker itself, and still doesn't seem to be enough power!
Am I doing something egregiously wrong here? I really just want a basic setup for my cable box/computer. I didn't think an amp would cost more than the speakers itself.
Any help you could give or links to amps (or do I need a receiver?) would be greatly appreciated!
post #2 of 2
you don't need a 300 watt amp, a 50-75 watt amp/receiver will be plenty. Just because a speaker can handle a high amount of wattage, it doesn't mean you need to buy one that powerful.
One of my receivers is 50 watts/channel and I used it with better speakers than your Sony for 8 years.
Are you planning to use your speakers just for two channel listening? CD's, MP3's etc or do you eventually plan them to be part of a home theater system?
It may make the difference between choosing a home theater receiver vs a stereo receiver.
