Hi All,
I searched the forums and found nothing similar to my problem.
I'm quite sure my problem is not related to misaligned signal data.
I have a two year old 37" Vizio SV370XVT LCD TV.
I've been experiencing a series of horizontal lines/bars flickering all throughout my screen. This occurs only if the TV has been off for about 10 hours,, then the lines slowly disappear after about thirty minutes of the TV being on. If I shut the TV off for more than 10 hours again, the problem returns. I posted a link below with pictures illustrating my problem.
I'm quite sure the problem is the TV itself, as this problem occurs on all of my three components connected to the TV, which are all connected to different HDMI ports.
I did a system reset via the menu, as well as unplugging the TV from the outlet, and pressing the power button down for 30 seconds. I also tried plugging the TV into a different outlet. Nothing resolved the problem.
My TV is out of warranty, so I was wondering if this is a job that could be done by myself, and what part I might need to replace.
Any help is much appreciated. Thanks.
So far your post has been the only bit of good information that I have found in all of my searching. It is too bad that the Vizio people can't seem to be able to diagnose their own products. Please excuse me while I go order my needed part. Installing it should not be a problem. I grew up in a TV repair environment, my Dad made a living doing that and I was his helper. That was in the early tube television days when they weighed a ton and were in nice wood cabinets. That's when the helper part came into play. He would marvel at what a TV is like today. Flat panel TVs were only a Star Trek thing back when he was alive.
