AVS › AVS Forum › Gaming & Content Streaming › Home Theater Gaming › General Gaming Help › Gamepad users! Which controller that you've used has had the best analog stick(s)?
post #1 of 4
Title says it all. Out of every gamepad you've used, which would you rate above the rest for the best analog sticks?
I'm talking longevity; how long it's able to hold up to usage without breaking or losing it's stiffness in the default location (resulting in a drifting cursor/character)
Another very important factor being smoothness and ease of movement; basically precision.
What is it? If somebody has a controller they hold above others that you've tried and disagree, say so! I want to find the best analog sticks available.
(Why am I asking this? I want to replace the analog sticks in my 360 controllers, as a side project more than anything. I'll worry about whether it will fit or not)
post #2 of 4
You've already found it with the 360 gamepad. Yes, they eventually drift, but by then you've gotten 500 hours of use out of your $40 toy. If you are absolutely concerned with the quality of motion, just buy a new 360 gamepad. Any replacement parts you'll find in the wild are going to be of questionable origin. Maybe they'll be original, maybe they'll be cheap knock-offs. You won't know until you install them and find them to be crap.
post #3 of 4
I have XBOX 360 controllers on my HTPC, I even have the "upgraded" silver ones. I do not find the analog sticks to be acceptable or accurate. I cannot speak too much about what is better since I have not tried much else for much time because for practical reason XBOX controllers just work with more games and what not.
post #4 of 4
I currently use two xbox 360 controllers for my HTPC, 1st for over 2 years and second for a year. The receiver did fail on the 1st one though, they apparently made a hardware change some time ago that fixed the issue.
  Back to Forum: General Gaming Help
