Originally Posted by
whiteboy714
Is flexraid running something in the background.
meaning?
This server feeds my HTPC, my deskop and wife laptop. Your saying if someone was reading or writing or using the server from another location it might matter?
For the record- I logged onto the server and used mediamaster on the server itself (I know I should not install that or do it that way but I wanted to test)
Same issue. Even on the server itself I get the same issue.
I have a Mediamaster folder on my Samsung RAID0 drive that I place all my stuff into - run mediamaster- and then move the finalized properly named and completed folder to the server for storage.
I copied some of the movies I was getting errors on with the server- I copied the folder to the Desktop and ran medimaster and it worked no problem.
The issue is not the files or the security settings it seems but something with mediamaster running over network on a network HDD.
Has anyone used mediamaster on a local machine on video folders stored on a server? Anyone every tried the rename all files and folders feature ?? Any errors?
It will download the metadata and album art fine. It just can not rename a file or a folder for some reason.
