AVS › AVS Forum › Audio › Surround Music Formats › DTS tracks and clipping
post #1 of 8
Hi,
Not sure this is the correct section for this question, but I hope so. I have some Blu-ray rips saved in .mkv files, with the DTS-Core extracted. I was curios to see how the waveform looks like for these DTS tracks, so I uncompressed them into wav/caf files and had a look at them in Audacity.
To my surprise, many of the DTS tracks I have checked have a lot of clipped samples. Is this normal? In other words, is it usual for the audio engineers to include clipped DTS tracks on Blu-ray's?
I am trying to figure out if something gone wrong during the ripping process or if they are just clipped from the beginning. It really varies depending on the movie, some are fine, some others are not. It seems the audio engineers do not follow any 'template' here.
Thanks for any opinions on this.
post #2 of 8
Be aware that dynamic range compression looks a lot like clipping. But in either case, sure they do it all the time. Either by boosting the gain and clipping the peaks, or by compression. Many movie tracks have enough dynamic range that if they lowered the gain to prevent clipping, most of the audio would be too soft. It may even be out of the control of the audio people who create the track, there's lots of people messing with it along the chain.
post #3 of 8
Even so, it's rather amazing that the audio track is allowed to be severely clipped on a production Blu-ray. Makes you wonder what kind of rules they go by. Is it allowed to be clipped as long as it 'sounds' ok? Did they even listen to it?
I still feel unsure about this. I have heard that a few clipped samples is nothing to worry about, but I am seeing much more than a few samples.
post #4 of 8
There are no rules, they do pretty much what they want. Violating specs and just plain bad mastering are common.
post #5 of 8
How do you know it's 'severely clipped'?
Digital clipping is level > 0dBFS, which manifests visually as a 'flat top' peak between two samples. Having peaks (not plateaus) that come up to, but do not exceed, 0dBFS is not clipping. At low resolution , audio that has been 'maximized' the latter way may look clipped, but zooming in may
show that it's not.
Furthermore, just because there is clipping, does not necessarily mean it's audible clipping...even if it's much more than a few samples.
And finally, there are no concrete rules against it. There are DVDAs and SACDs* that have actual digital clipping , as well as plenty that are 'maximized' via dynamic range compresson. "High resolution" on the label is no guarantee that the audio is 'purist' or has a high dynamic range.
(The SACD 'rules' -- the Scarlet Book specifications -- do discourage extreme loudness, but there are ways around them)
Edited by krabapple - 8/6/12 at 12:32pm
post #6 of 8
show that it's not.
I looked at the waveform in Audacity. It has an option to show samples that are clipped (showing them in red). I didn't do any zooming since I trust Audacity here.
Having compared many DTS tracks from various Blu-rays now, I see no consistency. Some of them have a beautiful waveform, others just look rather terrible with clipping.
post #7 of 8
The question is how does Audacity define 'clipped'?
The good starting definition would be: two or more consecutive samples at 0 dBFS. That, however, would by no means guarantee that it was audible.
I have seen software that flags single samples at 0dBFS as 'clipping'. That software is dumb.
(It can also be dumb the other way: clipped audio might be lowered in level so NO samples reach 0dBFS. Dumb software will say there is no clipping, but there is. The smartest clip detection routine I know of is part of Wave Repair)
post #8 of 8
(It can also be dumb the other way: clipped audio might be lowered in level so NO samples reach 0dBFS. Dumb software will say there is no clipping, but there is.Wave Repair)
Not sure what you mean by "lowered in level". If I look at a pure waveform in Audacity without dynamic compression applied, and it shows clipping, then I think the audio is clipped and the damage is done. It doesn't matter if the audio levels are lowered after that.
I have never seen this problem on AC3 tracks. They are always much lower than 0 dBFS.
I think for DTS tracks the engineers do not care about DRC or DialNorm, or anything else, they just try to maximize the audio volume of the track, and if they do some clipping they might not care. But they should.
  Back to Forum: Surround Music Formats
