AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › Anyone used Carnegie Fabrics Xorel fabric?
post #1 of 6
I came across this googling for acoustically transparent fabrics that had a pattern on them. It's a fabric called Xorel and the manufacturer claims it is acoustically transparent but I can't seem to find any acoustic testing information on it. Has anyone used this or tested a sample for transparency?
http://www.carnegiefabrics.com/default.aspx
-Alan
post #2 of 6
Not sure if you saw this, What is the pricing?
http://www.carnegiefabrics.com/Carnegie/PDF/XorelTestResults/Xorel%20Test%20Results.pdf
post #3 of 6
Hmmm, I wonder how that compares to GoM?
The closest thing I could find to an ASTM C 423 test for GoM was this: http://www.fabritrak.com/acoustic/1-2InchFabriTackwithFabric.pdf
I haven't looked into the price. I wanted to try to determine if it was actually useable first.
The particular Xorel style I liked was called Damask. That one doesn't appear to be one of the ones listed in their test results. I might see if I can get a sample of it. I could at least do the blow test.
post #4 of 6
The prices are all listed. There is also a pdf price list download.
The cheapest is about double FR701, and the most expensive over $100/yard. Plus $3 per yard cutting charge??? They only have to cut once. It is ridiculous to have a cut charge per yard at 10% of the total cost.
post #5 of 6
There are GOM fabrics with patterns
post #6 of 6
Many of the GOM with patterns listed in their "Acoustics" section are far from transparent. The 701 is terrific, but most of the rest are not.
