Hello my dear 3Ders! Here is one confused newbie on the 3d realm! I need help.
I bought a TV LG 47LW5700. Passive 3D. I understand that 3D formats can be side by side, top/bottom, checker board and frame sequencial. I see those selections when I manually switch from 2d to 3d.
What I don't understand is, when I am playing a PS3 3D game for example, it automatically switches to 3D, what format is it using? Is it one of the above or is it something totally different? Same when I play blueray 3d? Which one does it use?
I ask because I am trying to get my PC to work with my TV! I got cyberlink powerdvd 12 and the cyberlink advisor and it passes all except the TV. It fails the TV 3D. IT doesnt' detect or something. So when I launch powerdvd 12 ultra, I think I have to manually set the display and source types and I am not sure what to select for my LG tv.
in the power DVD, there are options:
3D Ready HDTV - (Checkerboard)
Micro-polarizer LCD 3d (LCD Interleaved)
120Mhz time sequential 3d LCD
HDMI 1.4 Enabled 3d tv. (1080P, 24hz)
HDMI 1.4 Enabled 3d tv. (720pP, 60hz)
HDMI 1.4 Enabled 3d tv. (720pP, 50hz)
Now, I know I am not HDMI 1.4. I am using 1.3 HDMI cables, and it works fine on my PS3. I have no idea and coudln't find anywhere in the manual what the LG 47LW5700 is? Is it micro-polarized? Or 120Mhz time sequential 3d LCD?? If it supports both, which one is superior? Which one matches the blue-ray 3d like Lorax 3d Blueray?
NOTe that I tried the 120 time sequencial and cyberlink said content or device doesn't support!
Thanks a lot for any explantion or help. If only the TV is detected as 3d, problems would be solved...
I have ATI Radeon HD 4670 BTW, which cyberlink advisor says passes 3d. I am assuming HDMI 1,.4 is not a requirement as my PS3 plays 3d without any problem using 1.3!
---- cyberlink Advisor output ----
Check Item 3D Ready? Info
CPU : AMD Athlon(tm) 7750 Dual-Core Processor Yes
__dwItemID=1001__ : szLibCPUName = AMD Athlon(tm) 7750 Dual-Core Processor 2.70GHz
__dwItemID=1002__ : dwLibClockRate = 2699
__dwItemID=1003__ : dwLibFamily = 15, dwLibModel=2, dwLibStepping=3
__dwItemID=1004__ : dwLibNumPhysicalProc = 2, dwLibNumCorePerPackage=1, dwLibNumLogicalPerCore=1
__dwItemID=1005__ : dwLibCorePerPackage = 2, dwLibTotalLogicals=2
__dwItemID=1006__ : szWMIName=AMD Athlon(tm) 7750 Dual-Core Processor
__dwItemID=1007__ : szWMIManufacturer=AuthenticAMD
__dwItemID=1008__ : dwWMIMaxClockSpeed=2700
__dwItemID=1009__ : bBatteryExist=0
__dwItemID=1010__ : szGuess=
GPU (Hardware acceleration) : ATI Radeon HD 4600 Series Yes
Hardware Dual-Video Decoding Capability for MVC : Unknown Unknown More Info
System Memory : 3072 MB Yes
Operating System : Windows 7 Service Pack 1 Yes
Graphics Card : ATI Radeon HD 4600 Series Yes
__dwItemID=1301__ : Adapter Compatibility: Advanced Micro Devices, Inc.
__dwItemID=1302__ : VideoProcessor: ATI display adapter (0x9490)
Graphics card video memory : 512 MB
Graphics Card Driver : 8.970.100.3000 Yes
__dwItemID=1501__ : 2D Driver=8.970.100.3000
__dwItemID=1502__ : COPP=Yes
__dwItemID=1503__ : RGBOverlay=No
__dwItemID=1504__ : DEVICE=N/A
__dwItemID=1601__ : Driver 0:
__dwItemID=1602__ : [F:] HL-DT-ST DVDRAM GSA-H62N
__dwItemID=1603__ : eHCMDrvType=0x00006fc7
__dwItemID=1604__ : CDRom=1 DVDRom=1 BDRom=0 HDDVDRom=0
__dwItemID=1611__ : Driver 1:
__dwItemID=1612__ : [G:] MagicISO Virtual DVD-ROM
__dwItemID=1613__ : eHCMDrvType=0x00000fc7
__dwItemID=1614__ : CDRom=1 DVDRom=1 BDRom=0 HDDVDRom=0
__dwItemID=1621__ : Driver 2:
__dwItemID=1622__ : [H:] VXDV BD-HD-DVDROM S10
__dwItemID=1623__ : eHCMDrvType=0x00054fc7
__dwItemID=1624__ : CDRom=1 DVDRom=1 BDRom=1 HDDVDRom=0
__dwItemID=1631__ : Driver 3:
__dwItemID=1632__ : [I:] VXDV BD-HD-DVDRAM S15
__dwItemID=1633__ : eHCMDrvType=0x002d6fc7
__dwItemID=1634__ : CDRom=1 DVDRom=1 BDRom=1 HDDVDRom=0
Blu-ray Disc Drive : [H:] VXDV BD-HD-DVDROM S10 Yes
Software Player : PowerDVD 12 Yes
Video Connection Type : Digital(with HDCP) Yes
3D Display : LG TV No More Info
Program version : 2.0.5302.0
System language : 0409 ENU English English
Time : Sun Aug 05 17:54:40 2012
System Name : DUCKY
EDID:
EDID BYTES:
0x 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 | 00 FF FF FF FF FF FF 00 1E 6D 01 00 01 01 01 01
10 | 01 15 01 03 80 10 09 78 0A EE 91 A3 54 4C 99 26
20 | 0F 50 54 A1 08 00 71 40 81 C0 81 00 81 80 95 00
30 | 90 40 A9 C0 B3 00 02 3A 80 18 71 38 2D 40 58 2C
40 | 45 00 A0 5A 00 00 00 1E 66 21 50 B0 51 00 1B 30
50 | 40 70 36 00 A0 5A 00 00 00 1E 00 00 00 FD 00 39
60 | 3F 1F 52 10 00 0A 20 20 20 20 20 20 00 00 00 FC
70 | 00 4C 47 20 54 56 0A 20 20 20 20 20 20 20 01 7F
80 | A7 C2 00 65 4D 00 00 00 D5 71 57 77 B0 3A 1F 03
90 | FE FF FF FF 9A 38 53 77 92 34 53 77 80 01 D6 0A
A0 | 00 00 00 00 00 00 2E 00 88 1A 7B 0D 80 1D 7B 0D
B0 | B8 2C D6 0A B8 00 BF 01 EB 03 00 00 EA 03 00 00
C0 | 00 00 00 00 00 00 2E 00 80 0F 7B 0D 01 00 00 00
D0 | 80 1A 7B 0D 60 FC D7 02 23 E0 52 77 88 1A 7B 0D
E0 | 38 01 D6 0A 01 00 00 00 80 1A 7B 0D 74 FC D7 02
F0 | 66 32 53 77 4A FB 51 77 2C 2B 53 77 FF FF FF FF
HDMI1.4 Capability:
ATI Radeon HD 4600 Series HDMI1.4 stereo: Unsupported
System Name : DUCKY
EDID:
EDID BYTES:
HDMI1.4 Capability:
