AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Narrowed down to 4
Narrowed down to 4
post #1 of 5
Hi All,
I need to replace my Onkyo 605, and I've done a lot of research and have the list down to 4 models:
Yamaha RX-V673BL
Denon AVR1913
Pioneer VSX-1122-K
Sony STRDH830
They all seem to have similar features and specs, and they all have desirable aspects to them. I will be using it for HT as well as music. I know people have their brand preferences, but does any one of these stand out in a way that I am missing? Why does the Sony look similar on paper, but is significantly less expensive than the others?
Any help that can be provided will be much appreciated. This has always been a great resource. Thanks.
Todd
post #2 of 5
Any of them, except the sony, is fine. Sony has fallen way behind their competitors in recent years. I would personally go with the denon for audyssey, but would be happy with any of them.
post #3 of 5
I'd suggest passing on the Sony as well .. choosing one of the remaining 3, although keeping in mind if you have a subwoofer in the setup, the Denon will be the only model that can EQ the subwoofer using Audyssey MultEQ.
post #4 of 5
I would not consider an AVR without Audyssey. That narrows your choices considerably smile.gif
post #5 of 5
Thanks for the opinions. My Onkyo had Audyssey, and I was impressed with it.
