AVS › AVS Forum › Audio › DIY Speakers and Subs › Custom Subwoofer for SUV?
post #1 of 8
I'd like to add a subwoofer for a Toyota Highlander, somewhere in the back, without sacrificing cargo/hauling space.
Anyone do something like this? What size is needed for an SUV?
For reference, I have a custom built 15" Sub for HT, but I heard you can get by with much smaller for car audio. Thanks!
post #2 of 8
You may be better off posting this in the car audio section, but the DIYers here will probably give you a hand as well.
Check this one out from Bill's site. It's his AutoTuba.
dbl
post #3 of 8
The rss390ho 15 does well in a small sealed enclosure.
post #4 of 8
dbl
Thanks, didn't even know it existed! This one is my go-to forum. I just posted in Car Audio. That AutoTuba looks like a beast!
post #5 of 8
Oh yeah, that's right! I'm using the RF at home and it is bigger than those mini-fridges you see in dorm rooms!
post #6 of 8
post #7 of 8
dbl
gah I want to build two of those for my epic 8s i have
post #8 of 8
it's the total opposite of a beast. An Alpine Type R 12 that can be had for as little as $99 in a sealed box with a 500 watt amp will have more output and take up less space. Even the 10 would be better. If you want a real small box look at the kicker L7 8 inch. The box can be as small as .33 CU. FT the 10 10 .66 CU. FT.
Edited by Manic1! - 8/27/12 at 3:42pm
