AVS › AVS Forum › Audio › Audio theory, Setup and Chat › Connecting Harman Kardon 2.1 Analog Speakers to LG LED HDTV with Digital out
post #1 of 11
Hi Everyone,
This is my first post here and I'm really hoping to get things cleared up. Hardware details are as follows:
TV - 47" LG LED HDTV - http://goo.gl/i4475 - This TV only has a "Optical Digital Audio" OUT. (No RCA out option)
Speakers - Harman Kardon Soundsticks III 2.1 - 3.5mm stereo - http://goo.gl/odJjg
What I need to be able to connect the two and be able to listen to the great sound of my speakers. I've been searching far and wide for the solution to my problem and I seem to have some doubts about the results. I think there are 2 options.
1) Toslink to 3.5mm Adapter - http://goo.gl/EzcQj + Toslink cable
2) Digital to Analog Audio Converter (DAC) - http://goo.gl/84IOh + Toslink cable + 3.5mm to RCA
Firstly, is there a third option out there? The first option just seems too good to be true. If there are such adapters that work, then why would someone chose a more expensive DAC, you know? I'm just not that confident about what'll work.
Just to put things in question form - What is the best workable combination to get sound out of my Digital TV to 2.1 Analog speakers?
I hope the above details are sufficient. Please let me know in case I missed something. I am hoping you guys can clarify stuff and suggest something that can work, hopefully from experience.
Thanks!!!
post #2 of 11
Hi AnDom,
Welcome to the forum.
Your solution #1 will not work. That adapter if for a standard optical connector to a 3.5mm optical connector, made for the multi-purpose 3.5mm audio-jack that Apple uses.
Your solution #2 is the correct one. There is one caveat, that may effect you (at least it effected me). My Samsung TV does not have the option to output stereo on the optical connector if the received TV station is broadcasting Dolby-Digital 5.1. It will only output the DD5.1 on the optical, but my TV also has analog-output jacks that always output stereo, so that might be the difference between your TV and mine. If that is a problem for you as well, then there are DACs similar to the one you linked to that also decode DD5.1 (for more money). It will depend on the LG. Check your menus for an option to always output stereo on the optical connector.
post #3 of 11
post #4 of 11
Originally Posted by MarkHotchkiss View Post
Hi AnDom,
Thanks for your prompt reply Mark!
So the options in my TV Menu for Digital Audio Out are - "Auto" and "PCM". Do you think a regular DAC would work?
post #5 of 11
Sorry about that Ratman. I kept getting an error that the server is busy. I never realized that I posted multiple times. Trying to figure out how to delete those threads now.
post #6 of 11
Yes. If you set the Digital Audio Out to PCM, the output will always be stereo, and that DAC that you linked to will be fine.
My assumption is that if Digital Audio Out is set to Auto, then the output would be DD5.1 when the broadcast is DD5.1, and stereo when the broadcast is stereo.
post #7 of 11
I have the same Speakers - Harman Kardon Soundsticks III 2.1 - 3.5mm stereo - http://goo.gl/odJjg
My tv is samsung lcd series 5 , 550 , what do i need to purchase to make these speakers work with my tv ?
thank you
dan
post #8 of 11
You need to get a digital-to-analog converter to convert the digital output of your TV to an analog signal.
The AGPtek is $20 from Amazon and will accept either an optical or coaxial cable from the TV set.
You will also need a cable with RCA jacks at one end and 3.5 mm stereo plug at the other end to connect from the DAC to the speakers; very cheap.
Edited by commsysman - 12/26/12 at 1:42pm
post #9 of 11
i bought the cables and tried them without that convertor , no go ! lol ... should have guessed it wouldn't be that easy . convertor it is . thank you ..
post #10 of 11
Always keep it as simple as possible...but not simpler...lol.
post #11 of 11
You mean after I get the digital to analog converter, like http://www.amazon.com/SANOXY%C2%AE-AGPtek-Digital-Optical-Converter/dp/B005DIRI6I , I have to connect the RCA to female 3.5mm plug like in this link below?
http://www.ebay.com/itm/3-5mm-stereo-female-mini-jack-to-2-male-RCA-Y-adapter-/270401259906
