AVS › AVS Forum › Classifieds › Display Devices › JVC DLA- R45 Projector AVS purchased and low hours
For Sale: JVC DLA- R45 Projector AVS purchased and low hours
post #1 of 1
This Classified is Closed
For Sale:
Will Ship To: USA and Canada
This projector has very few hours on it. Will update later when I am home and can check. I will also post a picture as well. The projector was purchased in May of this year. I am estimating somewhere in the 100 hour range on the projector and lamp. The projector was purchased here from the fine folks at AVS. So you know the unit is therefore fully covered with a warranty. I am also looking to sell my lens as well that is pictured too. It will be listed separately. Should you be interested in using this for a scope setup.
I apologize for the error on my previous summary. I had mistakenly listed this as the previous years entry model equivalent the X30 when in fact it is the RS45. Pictures are being posted this AM.
Here are the specs on this great projector.
The DLA-RS45 is a perfect entry into industry leading home theater performance. With a native contrast ratio of 50,000:1 and a host of new features for 2012, renowned D-ILA image quality is now available to a much wider range of enthusiasts.
Extraordinary Picture Quality
1920x1080(x3) 0.7-inch D-ILA devices
Upgraded optical engine and driver for smoother gradations and reduced motion blur
Native contrast ratio: 50,000:1
120Hz Clear Motion Drive for smooth action scenes
Highly customizable
6 picture modes and 3 color spaces
Darkness and lightness correction
Lens memory function memorizes 3 positions for focus, zoom and shift.
Maintains constant height for 2.35, 1.85, 1.78 on same screen.
Presets for different screen material
Stunning 3D Performance with active shutter glasses (optional)
Improved driver for increased brightness while reducing crosstalk
Parallax adjustment for fine tuning 3D effect
Highly customizable built-in 2D-3D converter based on high end JVC production design
Active shutter glasses and IR emitter are optional
Accepts all modern 3D formats (Blu-ray, side-by-side, top-and-bottom)
Optimum Flexibility and Convenience
Dual HDMI 1.4a inputs, PC input
LAN connection for system control and firmware updates
Remote control via LAN, RS-232C, IR
Newly designed remote controller with 3D function
V: 80%/H: 34% motorized lens shift
1.4:1 to 2.8:1 lens throw
Click for comparison of Reference Series 2012 Models
Edited by rlhjr34 - 8/7/12 at 5:20am
View All More from This Seller
For Sale: $275 (USD)
For Sale: $500 (USD)
  Back to Forum: Display Devices
