AVS › AVS Forum › Audio › Speakers › speaker quandry
speaker quandry
post #1 of 8
Hi There,
I have a bit of a problem. I have my own project studio (24 track hard disk and a 48 channel mixer with a bunch of hard synths). I use Sonar and Sibelius for everything.
Right now I have a pair of Event 20/20 BAS speakers which I love and still intent to use. However I was just given a Mctintosh 2300 amplifier in great shape. I want to utilize it in the studio but I can’t afford real expensive studio monitors.
Looking around with my small budget, I’ve seen a few brands like the Yamaha BR15 or the Yamaha BR12 which are pretty inexpensive. There are a few other brands like Peavy that have a similar product at a similar cost.
A few friends of mine told me that with the Mcintosh I really should be using a better studio monitor rather than the PA speakers I can afford.
Is it worth it to get the lower cost PA speakers or should I just bite the bullet and sell the Mcintosh (they are going for $1700 and up and stick with my 20/20 BAS.
Steve
post #2 of 8
For $400 you could get a pair of KEF iQ30 speakers, which are good enough to work well with the mac. Check the KEF Direct website.
post #3 of 8
I would look into the Behringer B2030P studio monitor speakers. These are very affordable and quite popular at Audioholics by folks how have owned them.
http://www.amazon.com/Behringer-B2030P-Ultra-Linear-Reference-Monitor/dp/B000N94S7O/ref=sr_1_1?ie=UTF8&qid=1344354793&sr=8-1&keywords=Behringer+B2030P
post #4 of 8
Looks good but the KEF iQ30 are only rated at 120 watts. That's too low for the 300 watt output of the Mac.
Steve
post #5 of 8
I've looked at them as well but they are only rated at 100 watts. I'd blow them up with the 300 watts on the Mcintosh
Steve
post #6 of 8
Steve
Huh?
Only if you turn the dial way too far... Just because an amp can give 300W doesn't mean it has to. There's only 4 dB difference between 120W and 300W anyway.
post #7 of 8
Dude, it's not like the amp is going to be putting out 300W all the time. Be reasonable with the volume and you'll be fine.
post #8 of 8
Yes, it doesn't work that way. Look at it this way, the Behringer monitors are rated 89db sensitivity with 1 wall at 1 meter. Meaning with only one watt of power you are at 89db from 1 meter away. With a 100watt receiver you will be pushing over 107db from 8' away. That is loud...
For reference:
http://www.gcaudio.com/resources/howtos/loudness.html
  Back to Forum: Speakers
