AVS › AVS Forum › HDTV › HDTV Technical › LG 55LM62 Dual Play issue
post #1 of 3
Hello this is my first post. I have a LG55LM62 and after waiting for months to get the dual play glasses (LG wasn't distributing them for a long time) I was finally able to try out one of the main reasons I bought this TV, Dual Play.
I have an Xbox360 and was trying to play a few games. I understand the loss of resolution and the stretching. What I am trying to figure out is how to get rid of the ghosting. You can see parts of the other side mixing in with what you are seeing, it makes it extremely difficult to see and play. Has anybody else had this issue? Is there any solution... games are at 720p I believe, if that makes a difference. PLEASE HELP. Thank you.
post #2 of 3
Bump, anybody else have this issue?
post #3 of 3
Welcome to AVS.
A couple of notes that might help you. First, we really discourage bumping.
Second, you'll get more help if you post display-related problems in the Display section appropriate for your set. HDTV Technical is for everything leading up TO your set.
  Back to Forum: HDTV Technical
This thread is locked
