AVS › AVS Forum › AVS Forum Information › Forum Operations Center › Can't edit my posts
Can't edit my posts
post #1 of 5
Since the "change" of the forums I can't edit my own posts, I hit the edit button, a "please wait" window appears, it remains there forever, I either close the browser or hit back, then I had to place a new post telling people I made certain mistake on the previous post..
Windows 7 X64
IE 9
[test edit]
SUCCESS EDIT, open in new window or tab works... it doesn't seem to work on the same window but I'll manage..
Maybe my IE is screwed or something I can't "suscribe" either by hitting the button, I have to choose options on the bottom to "suscribe"
Edited by DrLar - 8/8/12 at 2:41pm
post #2 of 5
As you can see, I just logged in as you (using WIN 7 64bit & IE9) and made an edit without issue.
post #3 of 5
Right-click on the edit icon, open in new window. That's what works for me.
post #4 of 5
I also noted the error on page, see if I can fix this permanently:
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 9.0; Windows NT 6.1; WOW64; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; InfoPath.2; Media Center PC 6.0; MS-RTC LM 8; .NET4.0C; .NET4.0E)
Timestamp: Wed, 8 Aug 2012 21:42:15 UTC
Message: Syntax error
Line: 1
Char: 1
Code: 0
URI: http://pagead2.googlesyndication.com/pagead/osd.js
Message: Object doesn't support this property or method
Line: 1
Char: 1688
Code: 0
URI: http://www.avsforum.com/mini/1344459421/basejs.js
post #5 of 5
Just tossing this out their....Do you have Java Script off in your browser or something like that?
  Back to Forum: Forum Operations Center
