After urgent advice as i want to make a purchase within the next couple of days.
As implied, I'm looking for a 46" - 55" LED tv who's primary sources will be standard definition free to air tv (via component), and downloaded SD tv shows (via HDMI and WiFi).
I realise that plasma is the way to go, but the tv is for my smallish bedroom which doesn't have any air con. Having previously owned a plasma, the heat it radiated was considerably annoying during summer, hence my want for an LCD.
It requires to roughly fall below the 55ES8000 price range. Unfortunately, i cannot afford a Sharp Elite Pro.
From the little info i've managed to find on the net, i've come to the conclusion that either HX850 or ES8000 are my best options. Am i right? If so, which of the two? If neither, please advise!
Many thanks in advance,
Jonathan Rocco
Edited by The_Frock - 8/8/12 at 10:00am
Jonathan Rocco
