Deciding on a new receiver and working the pros/cons of the networking feature. I understand the direct access to Pandora and the like, and some receivers also say that you can access DLNA servers.....but what I'm not sure about is the mechanism thru which you interact with these functions. Do you have to have the TV on in order to navigate thru a gui/OSD each time you want to use the function? or can you set up some defaults and then just turn the receiver on and go?
What else do/can you use networking for?
TIA.....gdog
TIA.....gdog
