Originally Posted by
Montagar
I have a Samsung S27A850D monitor that has a DVI-D (HDCP) input. The RNG150N cable box has an HDMI output. I have them connected together using an HDMI to DVI adapter. The setup menu in the cable box has a setting for HDMI/DVI that is to be used when using an HDMI to DVI adapter (stated in the manual). When I connect the monitor I get a picture very briefly and then just colored "snow". Has anyone experienced anything similar to this? Thanks.
If the cable box, using the HDCP protocol that is part of HDMI, cannot detect that the display is indeed a display, then the box can decide not to output over that HDMI port. I had this problem when running a comcast box into my AV receiver. I don't know if an HDMI to DVI adapter would prevent the HDCP handshaking between the cable box and your monitor. Try plugging into a monitor that has an HDMI input to test it out.
