AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Panasonic 65st50 Vs. Panasonic 65 gt50 Is THX important? and can you calibrate it to their specifications on the 65st50?
Panasonic 65st50 Vs. Panasonic 65 gt50 Is THX important? and can you calibrate it to their...
post #1 of 3
I just bought the 65" st 50 and I'm waiting to receive it. I'm a big movie buff and do trust the THX settings for realistic movie settings but the cost to get the GT was too prohibitive for me. Is there a way to still get to still calibrate the tv to the setting profiles they provide on their certified sets somehow. I'm new to the forum so I don't know if this has been discussed. Thanks in advance I appreciate it:-)
post #2 of 3
Recommendation is to "age" the panel for a good 150 hours - some like 100, others up to 250 - we saw changes in our 60ST50 out to at least 400 hours.
Personally, would get a copy of the AVS HD 709 disk, or one of the commercial alternatives (Disney WOW tends to get good reviews), and adjust YOUR set to suit YOUR eyes / viewing preferences.
Still, there have been a number of Recommended Settings posted on various sites - including this one, and these can make a good starting point. Try a search.
From memory, the settings posted with CNet's review of the ST50 were very close to those recommended by D-Nice for a non-aged panel.
We basically used Default Cinema or Custom depending upon source (with only minor changes) until our normal aging routine was "complete," and then used the AVS disk to adjust the panel - and still ended up with only minor changes from default Cinema for blu-rays.
One of these days, plan to get around to trying the DVE program with its fancy filters (have borrowed eldest son's copy), but PQ is so good that there hasn't been a lot of incentive to spend the time...
Enjoy your new set!
post #3 of 3
Thank you very much for your advice:-)
