AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › About a grand to spend, what 2 subs for reference level bass?
post #1 of 34
If you wanted 2 subwoofers and had about a grand to spend, what would you buy for the deepest bass?
I will be using Chase HT speakers as the speakers but not sure what subs to get.
post #2 of 34
Based strictly on that information and nothing else, I'd go with dual Epik Legends or dual Outlaw LFM-1 Pluses (when on sale).
post #3 of 34
I was looking at those Epiks. I need to read the threads on these, I heard of some issues with amps.
post #4 of 34
I don't know of any pair of subs that will get you to actual reference volume for $1000, unless you don't mind giving up a bit of the low frequencies nearing 20hz. Close, but not actually to reference in a typical sized room.
Reference bass is 115dB at the listening position and you lose spl as your seating position is further back from the subs. To get to reference levels with good clean sound you either need a small room on a $1000 budget, need to sacrifice extension, or up your budget somewhat significantly.
post #5 of 34
" Reference Level"..... This is gonna turn out bad, i can just feel it
post #6 of 34
Yeah it could.
I guess I should have asked best value subwoofers for $1,000.
post #7 of 34
DIY....
post #8 of 34
Yep, DIY. Otehrwise you are looking at buying the biggest baddest sub you can afford for $1000 and then getting a second one later.
post #9 of 34
There is a new company called Powersoundaudio that should start shipping next week, I hope anyway. Good bang for the buck on the XV-15's with the 5% discount and 10% on a pair. Unfortunately there is no owner feedback or any professional reviews yet, (at least that I know of) but these subs should perform just by who is building them.
http://www.powersoundaudio.com/
post #10 of 34
I would consider this Crystal Acoustics THX Ultra 2 Certified subwoofer. http://www.amazon.com/Crystal-Acoustics-TX-12SUB-Certified-Subwoofer/dp/B0051F0UAO/ref=sr_1_1?ie=UTF8&qid=1344540489&sr=8-1&keywords=crystal+acoustics+subwoofer
Note that the nomenclature is messed up and that you MUST look at the right model. The correct model is sold by Amazon for $749 in the above link. This sub just got a rave review by Jim Wilson.
You might consider buying one of these now and adding a second later. According to THX, you should end up with several of them to achieve true reference level. Even one of these would be pretty awesome if you could place it nearfield. That is, within 4 feet of the listening position.
Here is the link to the review by Jim Wilson:
http://www.avsforum.com/t/1421038/the-official-crystal-acoustics-subwoofer-owners-thread
Edited by spyboy - 8/9/12 at 1:10pm
post #11 of 34
#1 its too expensive.. #2 200 watts? I Epik Legend would roll right over that thing. He's way better off getting 2 Legends.
post #12 of 34
One hsu vtf 15 would be nice for a g also.
butter and jelly please.
post #13 of 34
You could name a bunch of single subs for under a g.. But he wants 2..
post #14 of 34
@ reference level even. Guess he could always blow out 2 subs and spend more in the long run.
post #15 of 34
He's probably not going to get 2 subs under a grand that will take a beating like that. The legends might or should. PC12-NSD's should but that's $1500.
post #16 of 34
Assuming cosmetics isn't the highest priority (because I'll admit the crystal acoustic sub is a looker) I'd spend a bit more $ and recommend the HSU VTF-15H for $1000, or the Epik Empire for $800, or the SVSound of your choice in that $1000 range, over the Crystal Acoustic sub for $750. (all of these subs I've heard and measured in my room, and in my opinion/experience the Crystal Acoustic is the weakest of these options --- though it is the cheapest). It won't get you to reference in pairs, their THX cert requires four of them. (see this link - http://www.crystalaudiovideo.com/ProductCatalog/Speakers/Subwoofers/THX.aspx)
The Crystal Acoustic sub doesn't scale very well either IMO. If you are spending $3K on these subs to get four at $750 a piece for THX Ultra spec, you are spending $3k poorly compared to alternatives like the JTR S2, the JTR Captivator, the Seaton Submersive HP, a pair of LMS-5400 or UXL 18s, or a FunkyWaves LMS-5400 setup. Each of these alternatives will get you well beyond THX reference level bass with just a single unit. (Albeit much greater expense ---and sans the official licensed THX badge). THX certification simply specifies reference level volume to 20hz (-6dB), which is a easy goal post that each of the aforementioned subs exceed for less or equal to the total $3k.
http://www.avsforum.com/t/1408856/crystal-acoustics-tx-12sub-omnimic-frequency-response-graphs/0_20
As I mentioned earlier. No two subs retail subs or ID subs for $1000 are going to get you to reference flat level bass in a typical home theater room. You can't even do it with DIY I don't believe. If there's a way - lets talk. KCNitro07 just spent $1k on DIY setup and he's not getting reference level bass in a small room. He used Dayton Audio Titanic MK III pair of drivers, in a couple DIY cabs he made, with some deckrestore as the cosmetic finish, and a Inuke DSP 3000 amp. Total price is right at 1K. Sounds good - but not reference, even in his small room. He can't take the volume much over -8dB without encountering clip lights on the INuke DSP amp. I've measured with him, so I know first hand.
Best pair of subs for $1000? Hard to say. I'd look at Epik or HSU or Outlaw -- there aren't many games in town. You could also do what KCNitro did for DIY - that worked out okay.
PICs
http://www.avsforum.com/t/1415823/2-dayton-titanic-mk-iii-15s-or-1-tc-sounds-lms-r-15/80_20
Measurements
http://www.avsforum.com/t/1415823/2-dayton-titanic-mk-iii-15s-or-1-tc-sounds-lms-r-15/100_20
He's fairly flat in room to 25hz, and then drops by 5-7dB to 20hz using REW calculated DSP on the Inuke. Almost THX spec if he could actually hit 109dB at 20hz which isn't going to happen with just a pair. He'd need four and that's $2k, not $1k.
If it were my $1000 and that was my hard ceiling - I'd buy a HSU VTF-15H and call it a day (not reference level but a darn good sub for right at $1k. Add a second if you find you need it and when you can afford it.
Edited by Archaea - 8/9/12 at 1:50pm
post #17 of 34
Maybe but the Legends (as opposed to the Empires) seem to have a disproportionate number of amp failures. Please don't take my word for it, there is a good bit to read in the EPIK thread.
post #18 of 34
As I mentioned earlier. No two subs retail subs or ID subs for $1000 are going to get you to reference flat level bass in a typical home theater room. You can't even do it with DIY I don't believe. If there's a way - lets talk. KCNitro07 just spent $1k on DIY setup and he's not getting reference level bass in a small room. He used Dayton Audio Titanic MK III pair of drivers, in a couple DIY cabs he made, with some deckrestore as the cosmetic finish, and a Inuke DSP 3000 amp. Total price is right at 1K, and he is still about 8dB below reference capability even in a small room. Sounds good - but not reference. I've helped him measure, so I know first hand.
PICs
Measurements
If it were my $1000 and that was my hard ceiling - I'd buy a HSU VTF-15H and call it a day (not reference level but a darn good sub for right at $1k. Add a second when you can afford it.
Hey buddy, IIRC your room wasn't a good match for the Crystal and Jim Wilson had better results.
post #19 of 34
The amp failure problem has been rectified. I have no issues with mine at all. Plus,Chad the owner will take care of you,he does actually care about his customers. I'd do the 2 legends for a grand.. Actually,if you buy one for $499,you get the 2nd one for $399. Your actually saving $100 for dinner with your wife/gf.. smile.gif
post #20 of 34
You can do it easily with DIY, and to 13 hz if you wish! The problem is they will be very big and ugly. 2 eD 190v2's, one behringer ep-4000, and one sonotube cut into 2 pieces and one sheet of MDF for endcaps. This comes in at $925 and in my room produced 120 dBs at the LP. Mine were tuned to 13.4 hz.
post #21 of 34
These
This whole system cost me $1500 for the 4. Two Cinema F-20's would cost $800-900 but only goes to 20hz.
post #22 of 34
20hz at -6dB meets reference as defined by THX standards...
but the f20's sounded quite muddy in my experience at the huskeromaha meet in 2011
Edited by Archaea - 8/10/12 at 7:45am
post #23 of 34
produced 120dB at what frequency? fairly flat across the spectrum? Did you happen to capture a FR graph at that time. For the price that seems pretty phenomenal, and I know you like your ED subs now -- sounds like a reasonable idea for someone who doesn't mind the looks. They are currently $150 a driver at ED in a sale right --- assuming ED is still legitimately selling things?
$150x2 = $350 shipped drivers
$350 = Behringer amp
$100 = sonotube
$40 = MDF sheet
$100 = mic2200 or some sort of HPF or EQ.
Yes that'd squeeze in at under $1000.
Sadly the ED thread shows a lot of discontent with orders right now. If you could do a local pickup this would probably work.
post #24 of 34
$100 = sonotube
$40 = MDF sheet
I know, if eD is still alive it would be great. One can always use another comparable driver. I would say the F-20 had a little more output above 20hz but I liked the eD's better which had better extension. Sadly, I only started measuring my equipment when I took those 4 subs and made 8 sealed subs(4 extra drivers and 2 extra amps). Here was the response with two separate setup locations(same subs and gear).
The first is all four corners
The response
Then I placed them all up front like this
The response with subs only and 80hz crossover
When I say reference I set everything to 75 dBs, subs 10 dBs hot, both vented and sealed, and watched WOTW famous scenes at reference and hit the meter at 126 dBs plus. My meter just maxed out at my LP which is 13-14 feet away.
post #25 of 34
The response
If I take away 2 subs(vented) it would hit 120 dBs in room at LP which is over reference.
post #26 of 34
MKTheater, your room has to factor in the equation though. You have a sealed, treated room which makes a big difference.
post #27 of 34
Although I doubt the OP would be interested in it, would an IB setup easily acheive the goal of reference level bass at $1k ?
post #28 of 34
I lose 12 dBs from the speakers to the seats! These two subs would play roughly 112 dBs at 20hz outside at 2 meters. Depending on placement one can get up to 12 dBs of boundary gain and maybe lose 3-12 dBs from distance. Dual ported 18's with 600 watts will get you there! My room is on concrete, so spl's are hard but pressure is easy. I can open my doors(7x6 area) and I lose nothing, that opens to another 2100 cubic feet.
post #29 of 34
Before we get too fired up about all this, we should try and find out more about the OP's room. How big is it, and is it open to any other areas of the house?
post #30 of 34
It does not matter, he wants the most output(reference from two subs for under $1000! The choices are very limited and basically DIY.
