post #1 of 1
$250 (USD) or Best Offer
send a PM to take the next step.
For Sale:
Panasonic TH-42PX600U 42' 720p Plasma
Will Ship To: Nowhere -- local only
This item is located in NYC.
I have owned this TV since March 2007; I am the original owner.
Still looks as good as when I bought it.
Includes A/V Console. I have the remote and User Manual. rolleyes.gif
Please ask any and all questions! There is no such thing as a stupid question!
Specs:
VIDEO:
Screen Size 42" Class (41.6" diagonal)
Contrast Ratio Up to 10,000:1
Compatible Signal Formats 480p/720p/1080i
Aspect Ratio 16:9 (Widescreen)
Displayable Colors Maximum of 29 Billion
Shades of Gradation 3,072
Pixel Pitch (H x V) 0.90 x 0.675 mm
Panel Type 9th Generation Plasma Panel
Aspect Control for TV/AV Modes 4:3, Zoom, Full, Just, H-Fill (PC Mode: Normal, Full, Zoom)
Native Resolution (Number of Pixels) 1024 x 768
Progressive Scan Yes
Video Noise Reduction Yes
Digital Comb Filter Motion Adaptive 3D-Y/C
Color Purity Optimizer (3D Color Management) Yes
Sub-Pixel Controller Yes
Motion Pattern Noise Reduction Yes
AUDIO:
Speakers 4(2 woofers: 8 ohms, 55 Hz - 350Hz, 10% THD)
(2 tweeters: 8 ohms, 350Hz - 17kHz, 10% THD)
31W Output Power
BBE ViVA HD3D Sound
INPUT/OUTPUT:
Tuners NTSC (Standard analog broadcasts) ATSC/QAM (SDTV and HDTV broadcasts)
Photo Viewer Yes (SD Slot)
SD Card Slot Yes (JPEG Photo Viewer)
CableCARD Ready Yes
HDMI-HDCP Interface 2 rear
Analog Audio Input (for HDMI) 2 rear
Composite Video Input 3 (2 rear, 1 front)
S-Video Input 3 (2 rear, 1 front)
Audio Input (for Video) 3 (2 rear, 1 front)
PC Input (RGB-VGA) Mini D-sub 15-pin (rear)
Audio Input (for PC) 1 (M3 Stereo Plug)
Component Video Input [Y, PB(CB), PR(CR)] 2 rear
Audio Input (for Component Video) 2 rear
Composite Video Output 1 rear
Audio Output 1 rear
Digital Audio Out 1 (optical)
IR Out 1
CONVENIENCE:
EZ Sync HDAVI Control: Yes, via HDMI interface
Video Picture Memory Yes
TV Guide On-Screen Program Guide Yes
On-Screen Display Languages English/Spanish/French
Picture-In-Picture Split Screen Display (2 Sources)
V-Chip Program Lockout Yes
Built-In Closed Caption Decoder Yes
Timers - Sleep/On/Off Sleep (Off only)
Video Input Labeling Yes
GENERAL:
Power Supply AC 120 V, 60 Hz
Power Consumption 399 W
Pedestal Stand Included
Remote Control Included
Dimensions (H x W x D) w/Stand 29.8" x 42.5" x 14.6"
Weight (lbs.) w/Stand 98.1 lbs
Dimensions (H x W x D) 27.2'' x 42.5'' x 5.5''
Weight 91.7 lbs (with with pedestal)
Leave me a message at (347) 448-2953 or contact me via the Forums if you like.
Edited by sc28 - 8/12/12 at 3:35pm
