AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Bryston SP3 vs. Classe SP800 vs. Audiolab 8200AP
Bryston SP3 vs. Classe SP800 vs. Audiolab 8200AP - Page 4
post #91 of 92
Originally Posted by Roger Dressler View Post
Hi Tony,
When you had the SSP-800, did you use the PEQ to good effect? It took me a while to get it dialed in, but I cannot see how I could use a unit that has no EQ, regardless of other sonic attributes. Sure, the SP3 can feed something as nice as a Trinnov, but even at that level of expense, it's another analog/digital cycle in the chain.
Yes, there's a lot of EQ out there I'd be happily avoid. Like anything I cannot tweak as I wish. I cannot tell if the Krell fits that or not. It uses the Cirrus DSPs that support PEQ, but whether they made them available I cannot tell from the manual.
If you left the EQ off, all the better for the comparison -- if your A/B memory is solid! biggrin.gif
My intention is to use the DSpeaker Antimode 2.0 to eq the subs. I don't recall needing much correction above above that as my room is pretty well treated. I will compare with eq off which I didn't consider doing the first time.
post #92 of 92
Hi Tony,
Very well said Roger!
