AVS › AVS Forum › A/V Control & Automation › Remote Control Area › Struggling to set up volume control....
post #1 of 6
I have the Watch tv macro set up so it turns tv on, PVR on, Amp (always on).
yet when i put my xbox media center on it wont control my amp volume, how can i set it so that no matter what device is selected my amp is ALWAYS main volume ???
Thanks in advance
TIm.
post #2 of 6
What remote are you talking about?
post #3 of 6
Sorry about that, its a logitech harmony one.
post #4 of 6
When you do your activity setup one of the first questions asked is "how do you control the volume". You check the line that says "I use my (whatever device you choose) to control the volume"
post #5 of 6
I done that, it only works if I select the amp under devices.any ideas what's wrong ?
post #6 of 6
Volume punch thru (always using amp for vol) only works on activites, not devices. If you added an xbox, you must make a "Play Xbox" activity to set the volume device. If you add another device in the future, it will need its own activity as well. You're probably used to other remotest that have a global volume punch thru. Harmony doesn't work like that. If you want it to work in device mode, just learn your amp's vol/mute buttons for every device. But using activities is much easier.
  Back to Forum: Remote Control Area
