AVS › AVS Forum › A/V Control & Automation › Remote Control Area › Onkyo tx nr 818 power codes
post #1 of 3
[Request} anyone have a file or something I can use for my MX-850 . None of the codes supplied with the editor software will work. I learned all the other codes from the original remote but the power is driving me nuts. TV and receiver are always out of sync . Not really sure how to paste codes to the editor program either . any help would be great. Wifes yelling all the time . If you know what I mean
post #2 of 3
You need to find the discrete power on and off codes (not power toggle) and paste them in (you'll have to figure that out, or pay someone to do it). Use power off in your master power off macro and power on everywhere else. Then nothing will ever get out of sync again. That's the only way to stop the yelling. Well, maybe flowers or jewelry would too, temporarily.
post #3 of 3
Well after tons of searching I got them here they are. IR_AVR_TX-NR717 TX-NR 818.xls 1706k .xls file
  Back to Forum: Remote Control Area
