Originally Posted by
NeuroradÂ
Wow, you're really taking off!
Yes, i'm actually starting to understand this stuff now. I'm no pro, but I will get there one day, the learning curve doesn't all of a sudden end for me right here and now because i've created a couple systems lol. Still a novice on that front. Getting there step by step
stefuelÂ
Double thumbs up. That's all it takes. The understanding of how to make just one thing work and you're off and running.
Now you have to start playing with various symbols to see what they can do for you and there's a ton of them.
Thanks! For what you're saying here, and myself experiencing it, I agree. These programming concepts that I previously have are starting to make connections to each other even though SIMPL Windows in itself is so different looking than what i'm used to. I can understand how things work because of my background knowledge, and I think that's the reason for why i'm progressing the way I am. I was looking at SIMPL+ versions of code actually on the Crestron WikiSpace and it makes MUCH more sense to me now. That place I found from the Yahoo Group was incredibly helpful.
amirmÂ
Good to hear you jumped over the chasm
. From here on it gets easier but never easy
Crestron did show the new software at CEDIA. While they are not going nearly as far as they should, it is a very big step forward. The software is still early though and is not broadly available. I think the tentative schedule is end of the year.
Yeah I seen some videos and reviews of CEDIA 2012... That Sony 4K is pretty awesome actually! I'm looking forward to seeing what Crestron comes out with next. They've been talking about a bunch of new software for various things apparently
NeuroradÂ
I'm considering a Crestron TPS-3000, to be used with a 2-series controller, for learning programming. Any thoughts? Hardwired, Cresnet, no battery or RF issues to contend with. Many 'nicer' touchpanels available, but I just want it for testing.
I can't say I have an answer for you, but I know that the TPS-4000L touchpanel that i've been working with lacks the graphic quality that i'm looking into dealing with. If you take the 3000 and 4000 as version numbers, even if i'm wrong to assume that, I can't say that the 3000 will be much better. Although it does the job, and Cresnet is amazingly simple stupid to deal with, it will power up the Touchpanel from the control processor as you've got the Power and data all in those 4 wires running through it. It's what currently helps power up my TPS-4000L when i'm working with it for communication.
I would LOVE to have a nicer touchpanel, but since i'm still learning I think it's best for me personally to make due with what i've got.
For you though.. You don't have things to work with yet? Then you've got free reign to gain feedback from the pro's here, and take their word on things based on what YOU are looking for, for when you first start practicing with this stuff, which could be a good thing!
Good luck friend
stefuelÂ
If all you are interested in is something to practice programming with then sure but if you are or think you may eventually would like to try your hand at fancy graphics, a TP with more real estate and power would be nice.
I'm kinda partial to larger screens as I'm a old fart with failing eyes. I still can spot a hottie jogger at a hundred yards though I can only appriciate it from afar.
Hahaha!
That's one of the reasons why I like my TPS-4000L; large screen. Although my eyes aren't bad yet, it's just nice to work with, both when creating a GUI, you've got more space for objects to put on a single page, and even when in use, it's much easier to use than a smaller screen.
Just my personal preference though at this point. I don't have any hardware preferences yet because I haven't quite worked with this stuff too much yet. I can't be an advocate for which is better over something else per say, so I just don't go there. As for now, it's just the specs and the "wow" factor
~Ace
