I need some help. I currently have a Samsung 58" Plasma that just went out but is under warranty. Since they don't make the panel to replace mine, Best Buy is offering me a new TV. They said I can either have the LG 60PA6500 or the Samsung PN60E530. Everything I've read on both has been positive with the usual "buzz" concern on the Samsung. I thought I heard a knock on the LG in the past, but I can't remember it. Anyone have an opinion on which is the better TV?
Featured Stories
Topics Discussed
- itemLG 60PA6500 Plasma HDTV
- categoryPlasma HDTV
- brandSamsung
Related Forum Threads
- I have a Samsung BDP and have issues with the player Picture Settings Last post on 2/27/13 at 7:10pm in Blu-ray Players
- Samsung F8500 - new industry standard? [please use links to newer thread] Last post on 4/1/13 at 5:32am in Plasma Flat Panel Displays
- Samsung PN50A550 Last post on 11/24/12 at 10:04am in Plasma Flat Panel Displays
- What's the DIfference: LG 60PV400 vs 60PA6500 Last post on 8/29/12 at 3:10pm in Plasma Flat Panel Displays
- Modern Plasma TV Life Expectancy? Last post on 8/27/12 at 7:34am in Plasma Flat Panel Displays
LG 60PA6500 vs Samsung PN60E530
Gear mentioned in this thread:
post #2 of 6
8/12/12 at 11:55am
I own the 60PA6500 and I don't have any regrets.
post #3 of 6
8/12/12 at 12:41pm
- videoguy60467
- Trader Feedback: 0
- offline
- 590 Posts. Joined 12/2001
- Select All Posts By This User
The biggest "so called knock" on LG sets, has been black level performance. The 2012 models are greatly improved. For most users, the set will be a good combination of performance and value.
For a mid range set, the LGs are very nice. The are also quite adjustable, and pretty easy to dial in good color without needing a full on calibration. Either set will be a solid performer. You could get better performance by looking at some higher end sets, (Panasonic ST50, Samsung E6500) but that may be a budget buster.
post #4 of 6
8/18/12 at 9:34am
I have seen both out of torch mode, and set up, the samsung was a brighter set with more "Pop" from my view. I ended up buying the Samsung. Colour accuracy is pretty good, blacks are better than my 3 year old Samsung as well.
A few things bother me though, I went through a few returns and could not get a set that did not have what I assume is DSE. On pure white scenes you can see slight pink splotches, its unnoticeable unless pretty much the whole screen is pure white. Also I could not get even close to optimal contrast for my whites, but black was pretty spot on calibrating, that being said it is not close to a 50 series Panasonic panels for those inky blacks. It also suffers some motion blur(phosphor trailing) and panning judder worse than I have seen on better sets which is slightly annoying but I guess you get what you pay for and is still much better than LCD sets I have seen on the blur any ways. There is buzz on my Samsung, although you can only hear if the sound is muted and you turn your ear to the TV. The last gripe I have is the set does not have the sharpness of other plasmas I have seen and raising it past 5 produces artifacts and going further then than causes bad noise forcing you to keep it between 0-5 (where it should be at on almost any other plasma) causing it to lose detail/ slightly muddy blurry faces. Like I said a Panasonic at 0 will be as sharp as this on 25 but without the artifacting/ noise.
On the plus side, I have seen no IR at all, even after pausing for long periods of time or watching football for 8 hours straight. Samsung panels seem to be immune to IR unlike the 2011/2012 Panasonic models. If you have any other questions let me know.
Edited by lmtech - 8/18/12 at 10:52am
post #5 of 6
11/17/12 at 7:20am
i bought the PN 60E530 AND CALIBRATED IT. I LOVE THIS SET FOR THE VALUE OF JUST OVER $1000 DOLLARS. BUT THE ONLY THING THAT I HAVE NOTICED IS THE WHEN I AM WATCHING THIS SET THERE SEEMS TO BE A SMALL BUZZING NOISE THAT CAN BE HEARD. I DIDNT NOTICE THIS WHEN I BOUGHT THE SET BOUGHT WILL SEE AS TIME GOES BY AND WILL CALL THE MANUFACTOR O SEE IF ANTHING CAN BE DONE ABOUT THIS. GOOD LUCK AND CHOOSE WISELY
post #6 of 6
5/17/13 at 5:21am
I have these exact 2 TV's and actually found this thread for comparison before getting both of them. Here's a quick rundown of my impressions. Just a side note, I 'did' tweak my LG to get better blacks via the procedures outlined here: http://www.avsforum.com/t/1372479/lg-plasma-panel-tweaks-for-better-blacks
The Samsung is brighter. On brighter scenes, it does appear that the Samsung has more 'pop' in its picture. It has slightly better color saturation, although the skin tones on the LG seems more natural to me during certain scenes. The E530 does have more noticeable buzzing if that's a big issue for anyone; it wasn't for me.
The tweaked LG clearly has better blacks, a few distinct shades darker on a mostly black screen, in fact (sorry for not being able to compare stock black levels; maybe I'll change it back for stock comparison's sake). The LG has better motion handling. The difference isn't noticeable most of the time, but during the dark city scene in "Samsara," (middle part of Scene 10), panning on the LG was smooth; on the Samsung, it was decidedly jerkier and had remnants of motion blur. This was tested using the same blu-ray player for each, by the way.
So if I could simplify it, the Samsung looks better in a bright environment, and the tweaked LG looks better in a darker environment. I use the LG as my main movie television as the jerky motion handling on the Samsung was a deal-breaker for me. Most of the time, however, side-by-side, the picture quality is pretty similar.
- LG 60PA6500 vs Samsung PN60E530
Currently, there are 1098 Active Users
(128 Members and 970 Guests)
Recent Discussions
- › DBP2011 & DBP-1611 owner's thread. All questions and comments go... 4 seconds ago
- › Microsoft fires the first shot in the "NEXT" generation.... 8 seconds ago
- › AVS Owner's thread for the pioneer elite bdp-62fd.. 21 seconds ago
- › "OFFICIAL" Pioneer SC-1222-K Owners Thread 28 seconds ago
- › HDMI cable confusion 35 seconds ago
- › Ugh... Too many choices! HELP! 39 seconds ago
- › Norco RPC-450TH - built in fan replacement? 1 minute ago
- › Dallas, TX - HDTV 1 minute ago
- › Boston, MA - OTA 1 minute ago
- › F8500.. OR .. ZT60 ????? 1 minute ago
View: New Posts | All Discussions
Recent Reviews
- › VIZIO 55 inch Class LED - M3D550KDE by indept
- › Optoma GT700 3D Game Time Projector by paul65000
- › InFocus X1A DLP Multimedia Video Projector by coastercard
- › BenQ W1070 1080P 3D Projector by arjjr
- › Epson PowerLite Home Cinema 8350 by Natros
- › Epson V11H501020 PowerLite Home Cinema 3020 2D and 3D 1080p Home... by sailorb
- › Elite Screens ER110WH1 Sable Fixed Frame (110" 16:9 AR) by DDT0C
- › Elite Screens ER100WH1-A1080P2 Sable Fixed Frame Projection Screen by DDT0C
- › Peerless PRG Mount, Black by DDT0C
- › Epson 5020UB Powerlite Home Cinema 3D Front Projector by DDT0C
View: More Reviews
New Articles
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
- › Clarus Power Cords by Good Tunes
- › A Theater Is Just Is Not A Theater, Unless... by David Bott
View: New Articles | All Articles
Home | Reviews | Forums | Articles | My Profile
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
