UVerse is connected through your phone line, if you are not in an area that is FTTP, which then you would have a ONT. As for Picture Quality, yes it can vary on how you are hooked up to the RG if you have one, or if you have a iNID, how good the coax is, that is connected to it, to the set top boxes.
I have our boxes that are connected to hdtv's set at 1080i, and only time we see any problems, is if there is a confetti drop on a tv show, or fast motion camera movements. Other than that, PQ is better than what Comcast can offer.
It is really up to the consumer to make the choice in what fits their pocket book, and what they watch on tv (ie sports). As for checking Signal Quality, it is always suggested to use UVerse Realtime, which can be found at http://www.uvrealtime.com, and look at the info in the IP Profile, Error Table, Bitloading, Coax/HPNA if connected via coax to the boxes.
Most of us that have our boxes connected via Cat-5e/6 have no problems as those with Coax connections to their RG.
