I replaced the fresnel screen on my 82" and got the part from SearsPartsDirect, though I could have gotten it from Mitsubishi at the same price.
If you download the service manual for your model, page 48 has the parts number you need, though you will have to determine if you have a type A or type B. The manual shows you how, as well as dis-assembly and re-assembly instructions. Definitely doable, if you take your time and handle carefully (with gloves, so as not to leave fingermarks).
PART ID NUMBER TYPE
SCREEN -LENTICULAR 491P208X50 A
LENS-FRESNEL 491P206X40 A
SCREEN -LENTICULAR 491P207X70 B
LENS-FRESNEL 491P206X60 B
