AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Marantz 7007 or Denon 4311
post #1 of 6
Any advice would be appreciated. Im about to purchase a new HT speaker system consisting of rf-7 ii, rs 62, rc64 and two svs 12 plus subs. Both receivers are roughly the same price but I am torn between the Denon model which states 140 watts per c vs the Marantz 125 watts. Anyone own either of them and have any advice. I have been told that the rf - 7 speakers need more power than the rf 82s I had been looking at. Thanks
post #2 of 6
4311CI hands down choice as it is 9.2 and uses the far more advanced version of Audyssey MultEQ XT32 vs. only XT on the 7007. A few of the current 4311CI/A100 owner's posting in the Owner's thread came from the older AV7005 and indicate a marked improvement.
post #3 of 6
^^^ this...
wattage is amoungst the last specs you should be looking at... however, the 4311 will handle those speakers with no issues...
post #4 of 6
I think Marantz is just plain STUPID for not offering a new pre/pro without XT32.
Just how many of these do they think they'll sell to people who haven't already bought an AV7005?
http://www.avland.co.uk/aasp/marantz/1220/av7701/av-7701.asp
AV7007 or AV7701 ... who knows ...
post #5 of 6
"...not...without XT32." Au contraire. If you seek Marantz and Audyssey MultEQ XT32, your double negative negates your point. Proofread before you post.
AJ
post #6 of 6
Gee, thanks for the English lesson, AJ.
