AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Ventilation question
post #1 of 2
While reading the Audioholics review, or the 4311CI, I noticed the had an overhead photo of the chassis, with the cover removed. When I looked closer, it appears there are two small "flushing" fans, underneath the amp heat sinks-are there actually ventilation fans in this unit?
post #2 of 2
Fans are pretty common in receivers. They tend to only turn on when a certain temperature threshold is reached though. Instead of a thread with an extremely vague title, go ask this question in the 4311CI thread where you will get an answer as to when the fans turn on.
