Changelog
Note
This changelog only applies to current stable build. For complete logs check links below.
1.6.3 - 14 August 2012
•New:
•New webpage (
http://mpc-hc.sourceforge.net)
•Source code moved to GitHub (
https://github.com/mpc-hc)
•The DirectX runtime dlls are included in the distribution packages so it’s no longer needed to install the DirectX runtime
•MpegSplitter: support for DVD-Audio LPCM and MLP in .aob files
•Use FFmpeg for AC3 and DTS decoding
•If the icon library is modified in a way that can break the icons associated to the extensions handled by MPC-HC, MPC-HC will automatically try to fix the registry so that each extension is associated to the correct icon
•Changed:
•Unrar is statically linked and so MPC-HC and VSFilter no longer need the unrar dll
•The Icon Library was rewritten leading to smaller size
•The Output Options page was redesigned for better usability
•Ticket #625, The translation dll’s size was decreased by 2/3 (uncompressed)
•Ticket #2227, Hide the seek bar in capture mode
•Ticket #2276, Use the new user interface on Vista and later for the Save dialogs
•Ticket #2342, MPC-HC will now use the Windows theme font for the Statusbar, OSD messages and a few other places on Windows Vista and newer
•Ticket #2378, Move the “Remember last playlist” option into the Options dialog
•Updated:
•Unrar to v4.20
•MediaInfoLib to v0.7.59
•ZenLib to v0.4.28
•FFmpeg (git 603221e)
•Little CMS to v2.4 (git eb67549)
•SoundTouch to v1.7.0pre r143
•Armenian, Basque, Belarusian, Catalan, Chinese Simplified and Traditional, Czech, French, German, Japanese, Polish, Russian, Slovak and Ukrainian translations
•Fixed:
•The hand cursor wasn’t shown in the web links in Keys and WebServer options page
•Toolbar code cleanup and background fix for Windows XP
•The last textbox used in the Goto dialog was not remembered since r3964 and r3965
•Always show an error message instead of crashing when the argument of a command line switch is missing
•OggSplitter: Fix crash with some files
•Logitech Keyboard support updated and made optional (Options -> Tweaks)
•WebServer: various bugfixes and improvements
•Ticket #504, Fixed rounding errors that prevented a properly centered image and caused unneeded resizing because the video size was off by one
•Ticket #2330, Fix the radio buttons in the Logo options page
•Ticket #2349, Recent Files: “Clear List” did not remove all files from the list
•Ticket #2356, The “With icons” and “File(s)” options in the Formats options page were not applied if no association was previously modified
•Ticket #2362, [DVB] Fix the Electronic Program Guide (EPG):
•Fix the parsing of the event’s information
•Fix the parsing of the characters’ encoding
•Fix the display of the start and end time when DST is observed
•Ticket #2365, The volume slider wasn’t properly redrawn in some cases
•Ticket #2427, The command line was not parsed when using slave mode
•Ticket #2470, API: Ensure that a 32-bit application can control MPC-HC 64-bit
•Ticket #2493, Fix a crash when saving subtitles using the sub format
•Numerous other bugfixes and improvements
