I tried searching the forums and found some similar questions, but I'm still a bit confused. Right now I have an IR receiver attached to my TV that routes all my remote IR commands to a repeater in a closet, which then sends the signal through emitters to my equipment. What I want to do is add control of my system using iRule in conjunction with a Global Cache iTach IP2IR, but I still want to be able to use my old remote as well. Here are my questions:
1. How can I feed both the signal from my existing IR receiver and the signal from the iTach into the existing repeater? I believe the repeater only has one IR input. Can I just use a standard 3.5 mm mono splitter?
2. To connect the iTach to the IR repeater, do I just use a standard 3.5 mm male-to-male mono cable? And do I use the IR blaster port on the iTach, or one of the emitter ports?
