AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Breaking in and calborating Panasonic 55st50
post #1 of 12
Hi All,
So I just got my tv and it's plugged in now. I am anal about my picture quality and I would like to get this right the first time. I know many will say get a professional to calibrate my tv but I want to see how far I can get myself. For the for 150+hrs on the TV, should I run a breakin DVD? Is so, where can I find one? Also, can anyone recommend a good calibration cd? I noticed AVS FD 709 and might give it a try.
post #2 of 12
Originally Posted by Viperlx View Post
Hi All,
AVS709 is good disk and can be downloaded for free, Disney WOW gets high marks also but is not free. I personally don't believe in the break in stuff, just keep your settings conservative watch varied content the first 100 to 150 hours you should be fine. Your set will improve alot in that time. After about 200 hours you should be able to dial in some pretty good settings. Good luck
post #3 of 12
I agree I adjusted using S&M disc and D-Nice settings without slides and watched TV thats what I bought it for and I still think it has the best picture
that I have ever owned .
i
post #4 of 12
thanks guys. I am going to run a breakin video over the weekend since I will be out of town. It won't hurt to accelerate the process a bit.
post #5 of 12
i
So you didn't do break in ?
post #6 of 12
That is correct I opened up the carton set up the TV in custom mode with D-Nice's no slide settings and put in a Spears & Munsil set up disc and tweaked it a little and watched TV .
Stayed up the next night and did color bar settings for OTA and Uverse and have been watching an outstanding picture ever since with no issues.
I should add as with all my electronics I let them acclimate to room temperature and warm up which is usually an hour before final tweaking.
Edited by oztech - 8/16/12 at 6:29am
post #7 of 12
As OzTech states it is not required, I have never done it on any of the plasmas I have owned. Now if you are trying to use Dnices post breakin settings then yes you should age the panel with his slides to get the best results.
post #8 of 12
when you say "age". do you mean the first 100hrs of breakin or 1 hour warmup?
post #9 of 12
He meant 100 or so hours:)
post #10 of 12
Hi All,
you can use the AVSHD709 disc right away to do a basic calibration, just be sure to recheck everything after the first 100-150 hours or so
post #11 of 12
I am not one to believe in copying settings (and most calibrators pro or not don't recommend it either), so I don't think using D-Nice's settings is a good idea. I'd either do a simple disc only calibration myself, hire a pro, or get a meter/software and do a full calibration myself. If fact, I do my own calibrations with a C6 colorimeter and CalMAN software and will be getting a used i1Pro spectro to profile it with soon.
post #12 of 12
He has two sets of settings one using slides with breakin and the other set as is and run it ,as for tweaking I personally like the set to be on an hour whether it be Plasma,LCD or CRT.
