I installed a IR repeater system and everything works through it except the Onkyo reciever. I can not get the remote to work through the repeater, it is a Xantech system. How can I get it to work?
Do your blasters include the visible red confirmation light? If so, do they flash in response to the remote? Or o you see or activity (view through a phone camera and IR should show up).
Any other devices being controlled by the blasters? Do they work?
It has a confirmation light that lights up when you use the remote. A cable box and a blue ray player are on the same block and both of those work. Yes I confirmed that the blaster works.
