AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › What to check buying second hand plasma?
post #1 of 3
Can anyone tell me a way to check for burn in?On light/dark screen?
Is there anything else to check when buying second hand plasma?
post #2 of 3
Bring an SD Card or USB Thumb Drive with the Break-In Images and run a slideshow. If there's any IR or Burn-In it will show up on the lighter colored slides.
post #3 of 3
