AVS › AVS Forum › Home Entertainment & Theater Builder › General Home Theater & Media/Game Rooms › Any advice for a very novice carpenter on building a bar
post #1 of 4
I found this and really like the idea for our media room downstairs. I like the bar behind the couch in the first two pictures and would like to something similar.
http://www.houzz.com/sofa-bar/ls=1
Does anyone have any advice on how to build it? I've been searching all over online for plans for other pictures but I've found very few...
post #2 of 4
Have you tried searching this forum and the archives of this forum There is a really large thread on bars and some fantastic work. I'll see if I can dig it up.
post #3 of 4
OK, found the one thread I was thinking of. But only because the thread starter happened to chime in on another thread with a link to his thread. I wasn't searching back far enough! His thread started in '06! Check out the HeyNow^ bar build here.
post #4 of 4
Awesome, thanks. I'll check it out.
