Just wondering what the most simple way to connect a laptop to the Crystalio II unit is so that I can run a Powerpoint off my projector. The projector itself does not seem to have VGA input so I am not sure what the best solution would be...
The CII accepts RGBHV through 5 BNC ports. It's one of the Component inputs along with the two sync connectors next to it. You just need a VGA to BNC breakout cable.
