AVS › AVS Forum › Audio › Audio theory, Setup and Chat › software Double Digtal Pro Logic II with a video captuer card.
post #1 of 3
I have a PS2 hooked up to my video capture card. I want to use software like Aud-X or AC3Filter to decode the Pro-Logic II that comes over the RCA cables of my PS2. If I use MONOGRAM GraphStudio to do this then I must also view the video from the card within GraphStudio, all though the pro-logic II is decoded correctly. This is a problem as filters such as DE-interlacing, up-scaling, etc, must be applied manually and I have not figured out how to do it as "nicely" as the capture card software does. The card is also easeir to control though it's own interface. If I hook the line-in directly to my sound card there is either a 1-secound delay or the sound scips when trying to use AC3Filter. Does anyone know how to achieve this? Is there software available to do this for me automatically? Thanks
-Jamie
post #2 of 3
Why not do stereo to stereo? Pro-Logic II can be applied by anyone with the means and desire to do so.
post #3 of 3
Because I have surround sound on my PC!
