AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Finding a display that will suit potentially opposing needs.
post #1 of 6
I've been in the market for a new TV to be used as a computer monitor for a while now. I am currently using a 42" Westinghouse that has been great, despite being a "cheap" brand, but my model had an S-IPS screen and has had no issues since I bought it for $1,200 6 years ago so perhaps I was lucky. However it IS getting old and has pretty cruddy black levels. I am a web designer and photographer, but also run a very large gaming clan. As such I need another IPS display for color fidelity (unless PVA technology has made some type of major leap I am unaware of) as well as decent refresh rates and input lag. I use a TV for this purpose as it doubles as an actual television when not being used as a computer (and most of my content is watched with all the lights off and blackout curtains drawn, thus the need for decent black levels). Here is a picture of my current setup(TV looks washed out do to the glare from my lights):
I would like to upgrade the size a bit to a 55" and get something with decent 3D. Unfortunately IPS is a bit of a "slow" technology so as I understand it, active 3D isn't really an option as none of the TVs run beyond 60Hz. Passive doesn't bother me particularly other than that I am going to be sitting very close and the spatial resolution is halved by the interlaced lines. Since this is being used as a monitor and has a lot of stationary imagery (taskbar, icons, etc.) I can't use Plasma due to the burn-in. It's a bit annoying that my needs seem to oppose one another such as:
Great picture quality (usually goes to plasma, on a per $ basis) - vs. - Stationary Imagery (anti-plasma, burn-in)
Color Accuracy/IPS display (slow refresh rates) - vs. - 3D/Gaming needs (high refresh rates)
I was hoping that someone on here might be able to help my juggle some of these issues and pick a suitable display. I'm not in a big rush, and could wait around until next summer with whatever gets launched at CES 2013 if need be, but want to upgrade soon. Here is a more concise list of my needs/wants. If any of this seems unreasonable that would be great to know as well.
TV Requirements
  • 55"
  • LED
  • IPS/S-IPS/H-IPS/α-IPS
  • Great black levels
  • Even backlighting
  • Passive 3D with minimal cross-talk
  • Low input-lag
  • <$2,200
TV Wants
  • Full-array backlight
  • Attractive aesthetics
  • IR input jack (for computer control)
  • <$1,500
Don't Need/Indifferent
  • Apps (will already have a whole computer to utilize)
  • Sound (hooked up to a few grand in sound equipment)
Edited by thatguyyoulove - 8/18/12 at 12:12am
post #2 of 6
There is no such thing as an IPS panel with great black levels. Just look at this year's LED-LCD lineup from Panasonic. Even the top of the line WT50 has poor black levels. The same goes for LG sets with S-IPS panels. Maybe if you can get your hands on a H-IPS panel set, you might get better blacks, but I'm not aware of any 2012 set that has one. The only way to get much better blacks from a IPS panel set would be to have a full array LED backlight with local dimming, but I don't know of any sets like that for 2012. Panasonic's WT50 has an edge-lit backlight with local dimming but it doesn't improve black levels in any significant way.
http://www.*********************/images/pdf/Shootout%202012%20contrast%20ratio.pdf
value electronics dot com
post #3 of 6
^^^^ I would pretty much agree with that. I would add though that guaranteeing that you will get a specific IPS panel let alone an IPS panel at all is difficult. Mfrs seem to use certain panels on certain models as long as the panels are available at time of build. Sometimes you can get a pretty good idea of what the panel type is by deciphering the complete product code but that is usually after someone has done a loupe test (> 10x magnifying glass) to examine the pixel structure and then noting the complete product code. The poor blacks on LCDs/LEDs can be mitigated somewhat by using a bias light behind the tv and that can be improved even further if the tv is properly calibrated. However, you will never achieve inky blacks like you can on plasmas.
Edit: there is also a chart somewhere (can't find it in my notes now) that lists panel types by the panel code which is usually visible from the back of the tv if you look thru the ventilation slots.
post #4 of 6
I was a bit afraid of that. Then again the black levels may still be significantly better than the TV I have. With my current TV whenever it is showing a black screen I still have to get up and turn it off because the screen is so bright I can't sleep (and that's with the backlight at 0 percent haha).
Local dimming doesn't really work for a computer monitor unless there is a LED for each pixel (never gonna happen) due to the precision needed and haloing.
I do however wonder if maybe I should just drop the IPS requirement and use a second monitor for color work. That would really open up my options. The kdl-55hx850 looks tempting.
post #5 of 6
If you want plasma like blacks (or close), you'll want either a S-PVA or S-MVA panel. The former should have wider viewing angles than the latter. Any panel should be able to produce accurate color on-axis if it has 10-pt grayscale and 3D CMS calibration controls. Off axis viewing is the exception and the color of black usually is too.
post #6 of 6
Yeah I'll definitely check those out. I will be calibrating everything via computer anyway so I don't need too much in the way of TV controls. Just get it as close as possible and then my calibration units will do the rest via the computer color profiles. Also I am a bit lucky in that horizontal off axis viewing is all within a 30 degree range. My desk, chair, and bed are all directly in-axis as you can see by my rough layout below:
I tilt the TV a bit vertically to split the difference in what would be on-axis vertically between the computer position and bed position.
