AVS › AVS Forum › Audio › Speakers › Bose Acoustimass 16 Speakers
post #1 of 5
My Acoustimass 16 is connected to onkyo 709 receiver. I get a thump sound when i on the receiver. Occasionally also get the thump when i change to different modes (DVD to CABLE or cable to games etc).
I bought the speaker and the receiver from the US for use Bangkok. They were converted from 110V to 220V! Please advice if have any solution. The Thump sound comes from the Acoutimass Module.
Edited by Roger77 - 8/18/12 at 3:24am
post #2 of 5
The Thumping comes from the Acoutimass module!!
post #3 of 5
It happens quite often. IC chips start to go bad and you get that characteristic thump changing sources or when turning it on or off. It should be fine for a long time until it totally goes.
post #4 of 5
Hi, u mean the noise will go away or till the sub woofer goes bust!
The sub woofers are less then 1 year old!tks !!
post #5 of 5
I doubt it is your sub. It is most likely the receiver. Speakers usually don't make any noise unless a signal from your AVR tells it to make some noise.
  Back to Forum: Speakers
