The simple reality is 16x9 is the standard for home viewing. In the vast majority of cases for films their respective ratios can be accommodated without losing their intended impact.
IMAX was, as with the adoption of wide-scope ratios back in the day, intended to be a wholly unique experience that could not be replicated in the home environment. A frame that not only filled horizontal peripheral vision but encompassed the vertical as well.
In order to properly replicate the intended experience of IMAX one would need a significantly larger squarer screen ratio; otherwise to accommodate what you are advocating within the confines of current HD spec would significantly reduce the impact of the IMAX sequences by pillar boxing them.
No one is disagreeing that the most likely cropping of the IMAX material to 1.78:1 for home use is a compromise but it is one that director was actively aware of and shot accordingly to accommodate. In order to retain maximum impact without compromising resolution to retain the increased clarity of the IMAX footage Nolan will once again crop to 1.78:1.
I can understand why you feel that this premise is a double-standard but it does not apply to this situation, most important reason is that Nolan shot the film in a manner to accommodate both 2.39:1 viewings and the likely BR presentation of 2.39:1 and 1.78:1.
Best Regards
KvE
Best Regards
KvE
(I know 1.78:1 isn't a theatrical aspect ratio, but most 1.85 films are "adapted" to 1.78 as well otherwise we would have tiny black bars, I guess the difference is negligeable in these cases, which means 1.89 to 1.78 is still the best choice
